Daz Studio 4.24[.0.x], General Release!
12357
  • barbultbarbult Posts: 26,565
    crosswind said:
    barbult said:
    I saved a scene in DS 4.24.0.3 and I unchecked all of the options in the popup dialog, including Render Settings. When I reloaded the scene, it changed my Render Settings. I looked in the scene DUF file, and it did indeed save a Render Settings section. Why? Is this a bug I need to report? Will Daz even fix 4.24 bugs anymore, if I did submit a help request?
    This was in the saved scene file. There was also a Tone Mapper section.
                    "id" : "Environment Options-1",
                    "url" : "#Environment%20Options",
                    "name" : "Environment Options",
                    "label" : "Environment Options",
                    "extra" : [
                            "type" : "studio/node/environment"
                            "type" : "studio_node_channels",
                            "version" : 4,
                            "channels" : [
                                    "channel" : {
                                        "id" : "Environment Map",
                                        "type" : "float",
                                        "current_value" : 2,
                                        "image_file" : "/All%20HDRI/HDRI%20Haven/All%20Free/Studio%20Small%2005/studio_small_05_2k.hdr"
    As far as I understand, the option of "Include Render Settings" doesn't include the nodes of Tonemapper Options and Environment Options, i.e. since they're Nodes, they'll be always saved within a Scene file ~~ (sb. pls correct me if I'm wrong ...)
    Then, if you want to keep the default values of Tonemapping & Env. in Render Settings, you can set a Render Settings Preset of those two nodes only in F2 > Scene > On Load > Post Open. Or, set a Script there to remove those two nodes ~~
    Hmmm, nodes seems like a plausible explanation. But Tone Mapping and Environment also appear in the Render Settings pane, so it seems somewhat ambiguous and confusing. Are they, or are they not, "Render Settings"? If not, why are they included and can be modified from the Render Settings pane?
    I wouldn't very often want to exclude those settings, but I would like to be able to sometimes exclude them via the list of items in the popup dialog. I thought by excluding Render Settings, I would exclude everything in the Render Settings pane. That seems like a logical assumption to me. That is not how it is implemented evidently. So I assumed it was a bug.
    (@crosswind I don't expect you to answer these questions. But it would be nice if someone from Daz could explain the logic behind this implementation.)
  • crosswindcrosswind Posts: 9,739
                    "extra" : [
                            "version" : 4,
                            "channels" : [
                                    "channel" : {
                                        "type" : "float",
    Actually I agree with you, and I also think there needs to be an explanation from Daz for this issue.
  • colongraphics colongraphics Posts: 84
    edited September 2025
    Lev_c said:
    The update has bricked Daz for me:
    Anyone got any solutions?
    Similar problem, with multiple crashes during a work session. I even went so far as re-installing windows 11 to ensure the drivers were up to date and a clean version of Daz 4.24 to try to fix the problem, to no avail. The access violation notification indicates that the program is is trying to access memory allocated to the operating system, so the program is shut down to avoid a computer crash. This might be a hardware problem with either the installed  RAM or the video card, a driver problem with the video card, or a bug in the Daz application. Neither Daz support or I have been able to isolate the problem, so I wish you better luck.
  • ImagoImago Posts: 5,692
    This happens on any scene or just some of them?
    I had a similar crash in the past months.
    Other than having a Genesis 8 based character in the scene, no. That doesn't really narrow it down very much. Maybe it would happen with Genesis 3 or Genesis 9 , but I don't use those characters as often so I don't see it. I can go through a few sessions without problems, but the scene I attached below crashed five times before I could render it. There doesn't seems to be enough consistency so I can isolate the problem. It is frustrating, not being able to have a consistant user experience.
    1920 x 1536 - 5M
  • ElorElor Posts: 3,590
    Due to the scripting bug with Daz Studio 4.23 on MacOS, I switched to the public beta, but now I would like to go back to the general release.
    I was able to transfert the UI using the script shared by Daz (here : http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/general_ui/copy_ui_from_channel/start ) but is there an easy way to copy the list of all the directory I mapped in the beta version?
    I can confirm that the access violation error did occur when using Genesis 3 figures. I am starting to suspect that a Windows 11 update in August is the root of the problem.
  • plarffplarff Posts: 282
    edited October 2025
    I have to say, I finally installed 24.3 version and I LOVE the dark UI with light green look so much.
    ps. I LOOOOVE the improved Spot Render options. Just so much better functionality. I think next for the Spot Render eveolution should be a Lasso type tool function similar to Photoshop if possible.
    Richard Haseltine said:
    Masterstroke said:
    In Darkside-Midnight UI mode, Transforms sliders in the Parameter tab don't have color background anymore?
    They are just grey now.
    Is this intended?
    Window>Style>Customise Style, in the 2D Axis group alt-opt click the colour pickers to reset them. It is intentional, but the default colours are unchanged.
    Post edited by plarff on
  • khasdannyakhasdannya Posts: 4
    edited October 2025
    why genesis 9 load so slow work so bad (freezes all!) and why ruin the genesis 1 morphs?!!! exist a way for delete all genesis 9 [stuff] and make genesis 1 useful again and yo udont care anymore????
  • LeanaLeana Posts: 12,975
    I'm not sure what problem you have but Genesis 9 does not impact Genesis 1 morphs, they're completely separate figures.
    I use almost exclusively Genesis 1 and didn't notice any issues until now. What exactly happens in your installation?
  • There has been an update to the Change Log, indicating that a new 4.x release is due before the end of the month. The last point is of particular interest to 3Delight users:
    Removed the 3Delight renderer plugin, the Scripted 3Delight renderer plugin, and all supporting 3Delight utilities from the standard distribution footprint - per license expiration EoY 2025
    If you are a 3Delight user, now is the time to make a backup of your current 4.x installer\IM package. It is not something unexpected, it was first announced back in July. Seeing that Thursday and Friday are public holidays, my educated guess is that the new release will be after the weekend. Don't wait until then to make a backup though.
  • nonesuch00nonesuch00 Posts: 18,830
    I've copied into an offline floder all thoose *DAZZStudio424* DIM installer files, but so, if from now on I only upgrade the DAZ Studio 4.24* Public Beta, and NOT the DAZ Studio 4.24 Release will the 3DL in DAZ Studio 4.24 continue to work?
    Can I just rename the current \DAZ Studio 424\ release folder to be \DAZ Studio 3DL\ (maybe I have to edit the registry and add it to DIM too?) and then reinstall the new DAZ Studio 4.24 without the 3DL plugin? I'm not sure what activations and plugin dlls are shared between DAZ Studio Publlic Beta and DAZ Studio Release
    Yes, you just need the isntallers in case you have to do a system reinstal, or get a new machine, or accidentally install the newer version.
    Settings are shared*, which is one of the reasons having two installations of the same version and release channel is not suported. People do do this, but it certainly isn't anything I would recommend.
    * I suppose if you launched one with a command line to give it a different instance name and its own settings you could avoid that to an extent, though you would have to watch the database path.
    Thanks
  • the_assassinthe_assassin Posts: 77
    edited December 2025
    What is the actual consequence of this 3Dlight change? What happens to all the old assets with old materials and shaders in my library?
    Post edited by the_assassin on
    They should remain.
  • BejaymacBejaymac Posts: 1,968
    Don't forget to download the Default Resources and store it someplace safe along with the installer for DS4.
    Post edited by Bejaymac on
  • FrankTheTankFrankTheTank Posts: 1,535
    The latest default resources for DS 4.24.03 seems to actually be for DS 4.23
    IM00013176-42_DefaultResourcesForDAZStudio423.zip
    Is that correct? That's what I have installed, I can't find anything more recent.
    Post edited by FrankTheTank on
    Default resources is updated only when there are chnages needed (I think the last time was for Filatoon).
    It should continue to have the 3Delight shaders as far as I know, but there is certainly no harm in making a back up.
  • VenkasVenkas Posts: 5
    Random textures will not load from my saved character scenes. It says textures cannot be found, but when I locate some of them, it allows the file to load and still shows me a missing texture list. One character had the scelra from the base eyes black. This is uh, kinda frustrating. I have to go through 14 different characters, figure what broke and resave them. Only affects anything from My Daz Library.
    Hopefully a database reset fixes my issue.
    Post edited by Venkas on
  • PenguinistoPenguinisto Posts: 85
    edited January 2
    So... about 4.24.0.4...
    Anyone else seeing not only a virus warning that has to be bypassed, but this error as well?
    (img attached)
    813 x 475 - 49K
    Post edited by Penguinisto on
  • JansillaJansilla Posts: 46
    So I downloaded and installed the latest 4.24.04 update via DIM. It ran OK but my studio icon has disappeared from the Win 11 desktop and the app is not findable within Windows although if I go to the Installed tab in DLM and use the launch option it opens OK. I've restarted the PC, re-installed the update but still the same. What have I missed here? Previous updates have not caused this issue.
    There's just no reason to install the new version. It adds nothing, it doesn't fix any bugs, it just removes a feature, 3DL, so why would you even want to install it? At least wait for an update that adds something new or fixes some bugs.
  • Richard HaseltineRichard Haseltine Posts: 109,462
    It does in fact have bugfixes http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log
    The desktop icon would go if the option to add one was not checked in the DIM Advanced Settings. I am not sure what steps you are taking when you can't find it in Windows 11 - click Windows logo ("Start") button>All>Daz 3D?
    Richard, thanks.  I've looked in the Advanced Settings of DIM and can see no options for adding the icon (or not). Just to add that I've not made any changes to DIM and it's worked with updates without issue in the past, so I don't understand why it's not behaving this time. It's as though the program is not registered with Windows: in the Start menu I have a folder for DAZ 3D but this only contains the DIM; if I search in the Start menu then it doesn't find Studio as an app only as an internet link back to the website; if I look in the Windows / Settings / Apps for installed programs then likewise it doesn't show up. But if I locate the EXE in the installation folder (on my C drive, nowhere exotic) or if I click the option to launch in DIM then the program runs. Do I uninstall completely and reinstall via a different route to fix it? If so, will I lose the settings for all my installed content...?
  • felisfelis Posts: 6,137
    Daz Studio is not in your list over apps, if it installed with DIM.
    When you have found the Daz Studio exe files, right-click and select Send to > Desktop (create shortcut) then you will get an icon.
