About "Duplicate formulas found in file" issue
mazinkaiserzeromazinkaiserzero Posts: 218
edited September 2025 in New Users
Hi, I know about this issue in general already but I was wondering, if loading a Genesis 8.1 figure gives you that error, should it happen as well when loading a Genesis 8 figure? (or viceversa)
It's my understanding that Genesis 8 and Genesis 8.1 share morphs so I would be inclined to believe that it's not possible to get a duplicate error only when loading one of them and the other one would be fine... right?
Post edited by mazinkaiserzero on
  • LeanaLeana Posts: 12,919
    G8.1 loads G8 morphs but G8 won't see morphs created specifically for G8.1.
    So if the morph causing the problem is a specific G8.1 morph you would not get an error when loading G8.
  • It is usually a conflict between two morphs, so if only one of them is for Genesis 8.1 then Genesis 8 will load without the warning.
