All Lights
Is there a reason why my distant light is not moving when I rotate my distant light?  I rotate it to the left of my image and the render shows it on the right side of the image. It's the same with the spotlights as well.
  • Richard HaseltineRichard Haseltine Posts: 107,953
    Distant Lights have diection but not location (they always shine from "outside" the scene). You are rotating the light node but the render/Iray Preview/Filament Drawstyle is not reflecting that? Are the lights set to point at something?
  • The lights point to the center of the render.
    If you rotate them  do their values in the Parameters pane update? Does the viewport a vatar (the block of three cones) update it's orientation?
  • Rotating the light(s) does not rotate the background light.
    Distant lights? Or are you talking about the HDRI environment? Some screenshots of what you are selecting might help.
  • What environment mode are you in under render settings?
    If it's Dome only, or Sun-sky only, no lights but emissive surfaces will add to the render.
    If that's the case, switch to Dome and Scene and it should fix your problem.
  • It is always on dome and scene, and it still did nothing to fix the problem.
  • I figured something out, removing the image from Enviroment Map worked. My light are placed where I wanted them placed.
