I'm new to this and don't know how to import an object along with its texture.
When I import this object together with the .mtl file, the textures do not load correctly. I think this problem is due to my lack of experience with the program. I would appreciate your help.
  • Richard HaseltineRichard Haseltine Posts: 107,953
    Please attach your image, embedded images are not shown properly.
    Are the image files in question present, in that location on disc? OBJ has very limited material settings in any event, so you cannot expect a geat deal.
  • Bunyip02Bunyip02 Posts: 9,236
    edited August 18
    A bit of a tutorial - hopefully Horo might chip in with a good recommendation for an advance tutorial on the subject.
    Click on File then Import Object
    Locate obj file
    Click on Obj group material
    Do a test render
    Some objs have multiple elements, to find out, click on the triangle
    Click on Select Meshes
    Post edited by Bunyip02 on
    edited August 18
    Continuing -
    Scroll down the list to the section of choice, click on it to select
    Check that the area selected has turned red. Next click on the M button
    If it did not load with textures, click on the first circle in the Diffuse row
    Click on the P button
    Click on Purple button above the P button
    Click on blank square next to the images to begin loading a texture
    edited August 18
    Continuing -
    Locate your texture file
    Click on tick to accept
    Do a test render to see how the change looks
    If you go and click on the M button again, then click on the Blue-Green button you get the Transformation tools.
    1916 x 1039 - 216K
    1922 x 1036 - 323K
    1916 x 1032 - 343K
    1922 x 1039 - 1M
    1919 x 1039 - 857K
    1919 x 1039 - 849K
    1929 x 1039 - 818K
    1919 x 1036 - 655K
    1919 x 1036 - 671K
    1919 x 1036 - 480K
    1916 x 1032 - 481K
    1916 x 1029 - 499K
    1911 x 1027 - 347K
    1919 x 1027 - 326K
    1916 x 1029 - 340K
    1912 x 1036 - 481K
    1919 x 1036 - 1M
    1912 x 1032 - 530K
  • HoroHoro Posts: 11,341
    bastiangarrido888 - get this free 11 page PDF document: https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf it should help you understand where objects, materials etc. belong.
  • mermaid010mermaid010 Posts: 6,046
    I have this problem only with most freebies, I normally have to texture the object from the images included in the file, just like Bunyip02 showed.
  • HansmarHansmar Posts: 3,135
    I recognize the issue and also use Bunyip's approach, or, preferably, change textures to procedural textures from Bryce to save many MBs.
