NVIDIA popup message upon Carrara new scene start
Greetings.  I recently replaced my computer.  Windows 11.  New computer has an NVIDIA graphics card.  New installation of Carrara. When I start up Carrara I get a pop up window briefly in the upper right of the Assemble room notifying me that NVIDIA overlay is available.
Has anyone seen this before?  What is it?  Do I want that to 'overlay' while I am running Carrara?
Perhaps unrelated, but I have noticed that Carrara now freezes if I do a spot render in the Assemble room.  Everything else seems OK.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,250
    its the shadowplay screen capture overlay, I have never seen it on Carrara though
  • HeadwaxHeadwax Posts: 10,434
    edited August 2025
    Good news you are up and running! For the spot render have you tried , in preferences under open gl there is an option to untick 'display lists' - wonder if that would help?" Probably not but worth ago. Haven't seen the overlay thing sorry.
    Edit
    Quick google says its a feature for games, giving you an overlay that provides stats eg frame rate ? Sounds harmless.
    Post edited by Headwax on
  • StezzaStezza Posts: 8,799
    I don't do gaming so I don't install the NVIDIA gaming driver set I only get the other option which I can't remember what it's called. frown
    when it works, its handy for tutorials, I find it hit and miss and resort to Win+G instead to capture stuff
  • DiomedeDiomede Posts: 15,393
    Edit
    Thanks for the tip about OpenGL.  Unticking the box seems to have done the trick.  I have only tested it on simple scenes, but so far so good.  yes
    Diomede said:
    Edit
    Double thumbs up
