Ultrascenery 1 - Uplands 2 texture issues
Steel RatSteel Rat Posts: 417
I've had texture issues with several of the Ultrascenery 1 features. Most were solved by an update a while back, one that I had missed for a long time. The Uplands 2 feature was one of those. The last time I rendered it with the Britain 5 ecology, it was fine. But today with Britain 6, the path on the bottom half doesn't appear. I don't see any missing textures, I can see the masks which layout the path, but it just doesn't render. I did spot renders with Britain 6 and Britain 5, 5 still works.
I noticed that 6 takes a VERY long time to start rendering, spending most of the prep time in "Updating materials", which leads me to believe something material-wise is missing.
DIM doesn't show any updates for US1, so not sure what to make of this.
I've attached the two spot renders for reference.
Post edited by Steel Rat on
  • barbultbarbult Posts: 26,390
    edited August 2025
    Problems like this should be posted in the product's commercial thread, rather than starting a new thread that will be overlooked and soon buried. Please post your questions there if you need help.
    I cannot reproduce your problem with default settings. Perhaps you made some change to the default settings that caused your problem - a change in altitude, water level, contrast brightness, etc.
    2000 x 1500 - 3M
    2000 x 1500 - 3M
    Post edited by barbult on
  • Steel RatSteel Rat Posts: 417
    I didn't make any changes. I used all the default settings when creating the terrain, and rendered.
    The commercial thread is very very long, and figured another comment would soon be buried and lost.
