Ultrascenery 1 - Uplands 2 texture issues
Steel RatSteel Rat Posts: 417
I've had texture issues with several of the Ultrascenery 1 features. Most were solved by an update a while back, one that I had missed for a long time. The Uplands 2 feature was one of those. The last time I rendered it with the Britain 5 ecology, it was fine. But today with Britain 6, the path on the bottom half doesn't appear. I don't see any missing textures, I can see the masks which layout the path, but it just doesn't render. I did spot renders with Britain 6 and Britain 5, 5 still works.
I noticed that 6 takes a VERY long time to start rendering, spending most of the prep time in "Updating materials", which leads me to believe something material-wise is missing.
DIM doesn't show any updates for US1, so not sure what to make of this.
I've attached the two spot renders for reference.
3000 x 3000 - 2M
3000 x 3000 - 3M
Post edited by Steel Rat on
    edited August 2025
    Problems like this should be posted in the product's commercial thread, rather than starting a new thread that will be overlooked and soon buried. Please post your questions there if you need help.
    I cannot reproduce your problem with default settings. Perhaps you made some change to the default settings that caused your problem - a change in altitude, water level, contrast brightness, etc.
    2000 x 1500 - 3M
    2000 x 1500 - 3M
    Post edited by barbult on
  • Steel RatSteel Rat Posts: 417
    I didn't make any changes. I used all the default settings when creating the terrain, and rendered.
    The commercial thread is very very long, and figured another comment would soon be buried and lost.
