New error, at least for me
I used DAZ yesterday creating a rather nice animation, using a GF8 model and Animate2.
After that, I bought a boatload of files in the evening, but didn't download them...SHAME on me.
This is the next day and I have a message I have never seen before..."The account referenced is not setup in Install Manager".
I'm afraid to just reinstall DIM, I've had issues in the past.
  • Is DIM set to store your log-in credentials or do you enter them afresh each time? Have you changed your email (or password)? Reinstalling DIM wouldn't help with a settings issue, which this appears to be. One possibility might be that something has happened to the account.ini file in
    %appdata%/daz 3d/installmanager/useraccounts/
  • ElliandraElliandra Posts: 642
    Another thing to note is that they are case sensitive. I found that out the hard way with the same issue my actual email is all lowercase for letters but I had the first letter capitalized and DIM said "Nope".
  • I password problem?? Could be, I will check that.
    That could be the answer to my next issue. I am unable to add any newly purchased items. I am down at least 10 items.
    I will check the password and hopefully that will fix the problem.
    As added info, I had DAZ installed on my 2T C drive. I needed more space so I cloned my C drive to a 4T drive.
    There were a couple issues where windows didn't like my Key #, Swapped out for a new Key # and after which all seemed good.
    I will follow up soon!!
