[SOLVED] DAZ opens, but you can't see it...
mikelsebastianmikelsebastian Posts: 35
I encountered a new issue yesterday, as i was playing in a scene i was making, i decided to change tabs to open YouTube to put a podcast while i work on the scene, but when i came back, DAZ was frozen, non-responsive, so i opened the taskbar and ended DAZ, so i can open up again, but this time, DAZ splash screen opens normally and all, but then it "Loads" and the whole window is non-existent, which is odd, because you can load up scenes and even when you close it, the window pops up asking if you want to save the changes.
Its hard to describe, but what im trying to say is that after the splash screen opens, the DAZ window is nowhere to be seen, its so ODD, its like its invisible, but of course you can't do anything because you can't see the window, so basically my DAZ broke, do you guys know how to fix it?
Im a bit nervous about deleting DAZ because i have a lot of custom-made stuff in it and I'm afraid that by deleting and reinstalling DAZ all of that is going to be lost.
Do you guys know how to fix it?
I attached some images for you guys to see.
The first image is the last thing it says on the splash screen before DAZ opens and the second images is how DAZ is seen on the taskbar, since, its non-visible in the screen, again, you can load up scenes and the loading window pops out, when you close it, the window asking to save also pops out, its so odd...
Any help would be greatly appreciated :)
Post edited by mikelsebastian on
