New Year, New Sales Thread: Report Issues Here 2 "Reporting Only"
16768707273100
  • Cris PalominoCris Palomino Posts: 12,669
    Snow said:
    No it's not.
    Has this turned out into one of those VIP member deals again or does it apply to all members?
    I believe it's everyone. Can you show your cart? We tried some carts and it's working.
    marduk999 said:
    When you put an item from your wishlist into your card, it looses any discount it had before it seems
    Was this before or after the fix?
  • felisfelis Posts: 6,081
    It is working for me now. Wasn't before.
  • Singular3DSingular3D Posts: 631
    Seems to work for for older items, but not newer ones. Both items in my cart at the same time with code WHAT-I-WANTED.
    Have been in my wishlist for quite a while now.
    T3d Realistic Strips 3 - Pubic Hair Genesis 9 Feminine
    $24.99 $10.00 60% Off
     FG Fantasy Pub
    $24.99
     FG Fantasy Pub
    $24.99
    Depends on what you mean by newer. This will not work on products still designated as new.
    edited July 2025
    OK, I got it. No price reduction by default but still designated as new.
    Post edited by Singular3D on
  • joannajoanna Posts: 2,414
    edited July 2025
    Not sure if this is a thread to report it, but I'm trying to post an image in the gallery and getting an immediate "Failed to save :( ...please try again" notification when I try to press "save" or "publish". Preview is working ok. Fields are filled out (title, description, no AI statement, tags, and some products), and there's no indication of what might be wrong.
    Edit: I waited an hour and it published. I guess it was some bad galleryway.
    Post edited by joanna on
  • ElorElor Posts: 3,479
    I don't think that the required product's link is leading to the correct Blender that is required :D
    https://www.daz3d.com/fast-animation-studio-tools--a-daz-to-blender-pipeline
    ok, that made me laugh.,.will report it.
  • Bunyip02Bunyip02 Posts: 9,288
    You could give it a whirl and see what result it will give !
    cheeky
  • NathNath Posts: 2,988
    Speaking of the Blender to DAZ product: the product page says  "Blender to Daz Studio 3.5.39" directly under Details (which is also the current version on the othere site that it is sold).
    But then, under "What's Included and Features" it says: Blender to Daz Studio Plugin 2.3.23.
    Some clarification would be good:
    • which version is included?
    • if it is the lower version, will there be upgrades, or am I better off returning the product and buying the most recent version elsewhere?
  • memcneil70memcneil70 Posts: 5,555
    edited July 2025
    Cris, I am having weird issues downloading 'Scatter - Ivy - With Ultra Scatter 2 Presets' SKU 110944. It failed the first try, then went, but when it showed up in my Installed Tab, the 'Uninstall' button was outlined in red. I was concerned the file had been corrupted, so I uninstalled it. And then deleted that package. When it reappeared in my 'Ready to Download' Tab, all I get now is Retry, outlined in red. The file in DIM shows 20.5 MB, the one in my Product Library for manual download has 20.6 MB.
    I had no other issues with the other six products I bought today, nor the two updates.
    Mary
    I tried again and the download went, but again the Install tab is showing a red line around 'Uninstall'. I don't think I have ever seen this before today.
    Post edited by memcneil70 on
  • frank0314frank0314 Posts: 14,765
    Mary
    Can you show a screenshot of this?
  • NorthOf45NorthOf45 Posts: 5,739
    I have seen this red outline several times. If the first attempt fails for some reason, the buttons retain their red outline, even if later attempts are successful. They clear up if you restart DIM.
    Mary
    Sorry, I only just now saw your request. I opened up DIM and it is as @Northof45 said, the file looks perfectly normal now. And a check of Installed Files looks great. I did open DIM on my Windows 11 computer earlier and downloaded and made sure to save this file for last. I let it go through by itself which it did without issue. I can only guess that the connection had a hiccup between Denver and Salt Lake City for a micro-second.
    Thanks for following up Frank.
    Mary
  • SilverGirlSilverGirl Posts: 3,253
    Fine print under High Tech Wishlist:
    Discount excludes post 2025 releases and Daz+ items.
    makes no sense. Post-2025 releases would be anything from 1/1/2026 or later. So unless there's some time travel at play here...
  • The High Tech Wishlist does not work, no 50% discounts after items are placed into the cart.
    Please can you fix this situation?
    1664 x 906 - 187K
    Have sent an inquiry.
    This appears to be working for me.
    1106 x 624 - 107K
    Text corrected.
    edited July 2025
    In the featured artists stores section, a text said that there is an extra 20% on Sci-fi items, but following the link to the selection of Sci-fi items, they have a 50% base discount, which is the same as the non sci-fi item and the 30% extra discount with a DNR doesn't seem to work either.
    Sci-fi selection: https://www.daz3d.com/sci-fi-stuff#index=0&order=popular^1&filtered=1
    General selection: https://www.daz3d.com/deepcore-artists#index=0&order=popular^1&filtered=1
    Here's an example with a cart:
    XI Royal Palace is a non-sci-fi item, and it get a 60% discount (50% base discount with the 20% extra discount due to the DNR added to the cart)
    The Street of Utopia is a Sci-fi item, and it also get a 60% discount when it should have 65% discount with the DNR in the cart. It also had a 50% base discount alone in the cart, when it should be 60%.
    636 x 483 - 59K
    Post edited by Elor on
     I reported this.
    Thank you :)
    Ok, so the items that get the extra discount are at https://www.daz3d.com/sci-fi-stuff#index=0&order=popular^1&filtered=1 and should be working now.
    Sadly, it is still not working for me ...
    793 x 521 - 122K
    1117 x 636 - 459K
    667 x 813 - 102K
    674 x 710 - 96K
  • Richard HaseltineRichard Haseltine Posts: 109,151
    Are those items from clicking on the View Wishlist button? It is only a subset of items that are in your WL and also in the SF category thata re included (I don't have any on my WL).
  • paolo_35229750paolo_35229750 Posts: 116
    edited July 2025
    They are the items shown from my whishlist when clicking the "wishlist button" on the promo, this takes me to the URL: https://www.daz3d.com/wishlist#index=0&filter_genre=Sci-Fi&filtered=1 which I presume only shows the applicable items, altough it does includes a 'New release' that doesn't qualify and is not in my cart; which includes the "Deep Space" new release item "dForce Nikol Pigtails for Genesis 9" and two other unrelated  items from today's promo.
    Post edited by paolo_35229750 on
    It'll show all Sci-fi items from your wishlist, wether they are eligible or not.
    Were they in your wishlist before the offer started ? If you added them since the offer started, it won't work.
  • Phoenix1966Phoenix1966 Posts: 1,886
    Same boat as the above user. These not new wishlist items have been on my wishlist since their release. As you can see, the 50% wishlist offer link isn't working as intended, since it shouldn't be showing me new, unqualified items, but it is. So I'm guessing the not new items must not be qualified for some reason, either. Or I've misunderstood the offer(never out of the question).
    1003 x 964 - 99K
    2533 x 1079 - 275K
