How to turn off this Green triangle's visiblity ?
Dont know what is this green triangle,   but it always shows up when I turn on or off  some object visibliility ,    this green thing can be rendered ,  I dont know how to turn it off   how ?
  • felisfelis Posts: 6,149
    Which object visibility?
  • crosswindcrosswind Posts: 9,746
    Right-click on it in Viewport, see what you find in the menu, and if it can be selected. Better post a screenshot and/or name the product you're using.
  • Richard HaseltineRichard Haseltine Posts: 109,519
    Try hiding any fitted items one-by-one and see which, if any, it vanishes with. If it is a fitted item, was it one converted from another figure through AutoFit? It looks like some kind of posing handle, which would usually be a separate bone that could be hidden on the original but any conversion would have integrated it into the basic figure groups.
  • Lan2050Lan2050 Posts: 14
    Thank you for the reply , it cant be selected , and cant be seen in the outline list , and its  visible on/off follows the root of that model,   it is a old poser model ,  when newly add to the viewport,   it dont shows,  but when ctrl click on it's root off then on,   this green arrow shows up and can never be turned off .   I can  goes with it now,   this thing has costed a lot time already ,   I will just drag it below the ground when I dont want see it ,   I think this is a fast solution .   Thanks for concern.
  • Ah, in the Scene pane option menu (the lined button in the top corner, or right-click the tab) enable Show>Show Hidden Nodes - I think you will then see, and be able to hide, the bone for this.
