How to turn off this Green triangle's visiblity ?
Lance97
Dont know what is this green triangle, but it always shows up when I turn on or off some object visibliility , this green thing can be rendered , I dont know how to turn it off how ?
1080 x 861 - 271K
Which object visibility?
Right-click on it in Viewport, see what you find in the menu, and if it can be selected. Better post a screenshot and/or name the product you're using.
Try hiding any fitted items one-by-one and see which, if any, it vanishes with. If it is a fitted item, was it one converted from another figure through AutoFit? It looks like some kind of posing handle, which would usually be a separate bone that could be hidden on the original but any conversion would have integrated it into the basic figure groups.
Thank you for the reply , it cant be selected , and cant be seen in the outline list , and its visible on/off follows the root of that model, it is a old poser model , when newly add to the viewport, it dont shows, but when ctrl click on it's root off then on, this green arrow shows up and can never be turned off . I can goes with it now, this thing has costed a lot time already , I will just drag it below the ground when I dont want see it , I think this is a fast solution . Thanks for concern.
Ah, in the Scene pane option menu (the lined button in the top corner, or right-click the tab) enable Show>Show Hidden Nodes - I think you will then see, and be able to hide, the bone for this.
