[SOLVED] Looking for long sleeve crop top
Hi everyone,
I'm once again reaching out to the community for help. I'm looking for a long sleeve sheer/transparent crop top like in the attached image. Would someone be so kind and helped me identify it? The top seems to be sheer/almost transparent. It looks similar to some products from xtrart-3d, but unfortunately those aren't as ''clean''.
Image removed
Thank you everyone in advance.
Post edited by Magikarp777 on
You need to crop the image before it can be posted on the forums, I'm afraid.
Thank you, richardandtracy, I will look into it.
My apologies for the previously attached image. I did not intend to cause any trouble. Would cropping out the exposed nipple be enough or do I need to crop out most of the breast as well?
I'm 90% sure I found what I was looking for. It's most likely the top from this outfit https://www.daz3d.com/after-midnight-outfit-set-for-genesis-8-females.
Still, thank you both and also everyone else.
Have a great day.
I think you would have to crop the exposed part of the breast:
https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity
Yes, I think the back and arms will stil show the effect you want.
I think the one from Pretty3D is close, but it is not the same.
The one you showed pictures of was more loose than the one from Pretty3D.
This is my take on it.
