mesh deform
sainrocky484sainrocky484 Posts: 5
edited July 2025 in Daz Studio Discussion
hi guys . I try to convert genesis 3 model morph to genesis 2.all thing are down and have ajust to rig to shape after making morph it work perfectly .but when pose it deform of hand area .what should do to correct them. or it there  a better way to make genesis 8,genesis 3 make theri model morph for genesis 2.
also i have some doubt why genesis 2 model have 40k + ploygne compare to genesis 3 which has 30K polygon.
Post edited by sainrocky484 on
  • barbultbarbult Posts: 26,583
    Did you remember to ERC freeze the converted character after adjusting the rigging?
  • sainrocky484sainrocky484 Posts: 5
    edited July 2025
    yes i have use ERC Freze and unchecked restore figure save that.
    430 x 527 - 42K
  • Richard HaseltineRichard Haseltine Posts: 109,488
    edited July 2025
    You also need to restore the rigging (first option checked, or it is in the Joint  Editor right-click menu) otherwise you will get both the ERC-linked changes and the raw changes from adjusting the rigging, doubling the effect.
