• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Exporting to OBJ with materials included
kenmokenmo Posts: 1,055
June 2025 in Blender Discussion
I am having a lot of difficulty exporting BLEND files to OBJ with textures and materials included.
When exporting I do select to include materials and COPY as the path mode.
It appears to be hit or miss.
I do realize that Blender can not export Blender's shaders without going through the very convuloted and tedious baking routine.
o it is not shaders I am asking about.
I can't remember having this issue with earlier versions of Blender 3.X having this problem.
I am using Blender version 3.6 LTE and have tried various releases of Blender 4 with the same problems.
Is there a good addon that exports OBJs with textures and materials?
And PLEASE do not recommend FBX format. I have nothing but issues with FBX in Vue.
Any mentioining of I should used FBX I will take as trolling. So please do not.
  • PadonePadone Posts: 4,021
    July 2025
    As I know it, obj will only export the basic textures if you use the principled shader for materials, any other shader setup can't be exported.
    https://docs.blender.org/manual/en/3.6/addons/import_export/node_shaders_info.html
  • lilweeplilweep Posts: 2,747
    July 2025
    obj is not a blender to daz bridge and never referenced all maps correctly btw. https://www.daz3d.com/forums/discussion/comment/9190856
    As you are asking for addons, there is a blender to daz bridge addon on blender market or hivemarket or whatever its called now
    it will only work on the blender principled bsdf shader, so as you say you need to bake any complex shaders down to textures
  • kenmokenmo Posts: 1,055
    July 2025
    _info.html
    I realize this. However I when I exxport to an OBJ I and check off all the susggested fields (see my attached screen capture above) i get the .MAT file but no image textures.
    July 2025
    I was not posting about the Blender to Daz Bridge. I was asking about exporting from Blender as an OBJ and when I select the recommended fields and settings to include image textures, I only get the .MAT file.
    July 2025 edited July 2025
    Just tried a simple cube with the diffuse texture and works fine here. You may check the mtl file to see if textures are included, the path can be either relative or absolute I tried both.
    p.s. Unless you expect the obj exporter to embed textures or collect them for you that of course is not gonna happen. Eventually you can pack then unpack if this is what you want.
    file > external data > pack/unpack
    Post edited by Padone on July 2025
    July 2025
    My .MAT files do not reference any textures or any path to textures liked they did when I used earlier versions of Blender that gave two options for exporting OBJS. One was legacy export to OBJ which I always used and worked flawlessly. This option is no longer available in newer versions of Blender.
    And FBX is a no go. Does not work properly importing into DAZ, Vue or Modo and a hit or miss with 3D Coat.
    The material file is not "mat" but "mtl", then 3.6 includes both the legacy and new obj exporter, if you don't get it then reinstall blender. I tried the obj exporters in 3.6 and 4.4 and they all work fine for me so I have no idea what you may miss. Below my options.
    p.s. It may be that you move the obj file after it has been exported, then if you save as relative path be sure to move the textures along, or use absolute path.
    277 x 256 - 18K
    July 2025
    Mistake on my part. I meant MTL file. Not feeling the best today, having some health issues. When I open up the .MTL file in notepad, there is no reference to the diffuse, normal, bump, etc maps. yet the original file has image textures applied. Even models I have created in Blender and UVMapped in 3DCoat (using the Blender/3DC addon) I can exchange the model from Blender to 3DC and back to Blender with any texturing I've done in 3DC. If I export as an OBJ from Blender there are no textures most of the time. If I import from 3DC as OBJ it does include the textures which I can not import the model with textures into Vue or Daz. When I export from Blender and import into Vue or Daz there are no textures. It is a Blender issue.
    If there's no textures in the mtl file it is likely that you didn't use the principled shader, or didn't plug the texture directly, as already referenced above. I see no other reason why this should happen. Again works fine here on my side I can export textures from blender to daz studio, so it has to be something you're missing but no idea what apart as already explained above.
    July 2025
    As I said above, I mostly use 3DCoat to texture my models, even the ones I modeled in Blender. When I export from 3DC and import into Blender the textures appeal.
    Yet when I export the  same model from Blender they do not.
    July 2025
    Well if you can share a simple blender scene which doesn't export I can check if it works on my side and let you know what I find. Please as simple as possible.
  • gregsgraphics_cafd0962a0gregsgraphics_cafd0962a0 Posts: 112
    July 2025
    You mentioned you use the "Copy" method for materials when exporting from Blender.  With that method, I believe the textures assigned to your materials need to be in the same directory as the model upon export.  However, if your mtl file that is generated does not at least contain the names of the textures, then something went wrong there.  Copy will not copy the textures to where you export the files like it will for FBX export.  They have to be there already.  Try using AUTO or either ABSOLUTE or RELATIVE for the materials.  Either that or copy the materials you know are attached to that model into the same folder as the .blend file before exporting the object.  You'll need to change the paths of the materials in Blender after you do that to point to the new location, assuming they weren't in that same folder to begin with.
    July 2025
    Thanks, I'll try that.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
