Conforming bone and organ system for better\accurate Subsurface rendering
Just a thought, a good conforming system for G3\G2\G1 characters that would help with the sub surface PBR.
  • Oso3DOso3D Posts: 15,127
    Either that or some sort of 'tissue map' that would define some sort of series of depths that translucency and refraction occurs at.
  • larsmidnattlarsmidnatt Posts: 4,511
    You can make your own SSS maps for this if you need it. However by the nature of it, it is a fairly sublte thing. So not sure most people need bone and organ SSS rendering specifically. Definately not geometry.
  • takezo_3001takezo_3001 Posts: 2,044
    edited October 2015
    Indeed, as iRay and Lux render would have to do much more work in loading and rendering the extra geometry that would only have a subtle effect Anyways..If you REALLY want to use skeletal geometry, then why not simply apply a push modifier on a dupped character and shrink them into your character?
    Post edited by takezo_3001 on
