• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Lower clothing poly count without destroying UV Map
jwcjaygainesjwcjaygaines Posts: 72
June 2025 in Blender Discussion
So here's what I have going on: I'm using the Montana outfit for G3 on a G8.1 in Blender. I've noticed that G3 clothing tends to have a higher poly count than G8, even at base resolution. I tried using the Decimate Modifier with Un-subdivide set to 2. It did a great job and didn't destroy the topology by creating polygons or triangles. The only issues are the UV maps and their corresponding textures. Now the side seam of the pants has weird artifacting in the texture, and when I went to the UV editors, the areas of the seams were chaotic. I know if you only use 1 level, it creates a diamond pattern (rotating the squares 45 degrees). The Collapse and Planar options keep the correct UVs somewhat, but it creates HORRIFIC topology once you apply it. Is there a workaround to this?
  • Richard HaseltineRichard Haseltine Posts: 109,523
    June 2025
    Is the issue completely scrambled UVs, or it just broken at the seams (where different areas of the map join)? This isn't a Blender feature I have used, but is there an option to protect UV seams if it s the latter you are hitting?
  • PadonePadone Posts: 4,083
    June 2025 edited July 2025
    Unfortunately unsubdivide can't keep the uv islands, also I don't know of any software capable to do that, any polygon reduction tool keeping the uv map seems based on triangles. However, it is possible to unsubdivide within uv islands, this way the uv island border is not affected thus uv maps are preserved. This is implemented in diffeomorphic so you can just use the tool there.
    mesh > lowpoly > make low poly
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Mesh Tools/Low-poly/Make Low-poly
    Post edited by Padone on July 2025
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
