Introducing Character Into Scenes
Hey guys I have been using daz for 2 years now, I always wondered how you guy introduce character in the scene. I have been saving them seperately and use to merge the enviornment and  characters by going to File>Merge. I am not sure if this is a correct method but I havent asked and always wonder is this a right way to do it.  Also if there is any other way does the other way helps in making scene less heavy and cost less VRAM ?
  • felisfelis Posts: 6,109
    I would suggest a scene subset or Persona preset.
    A scene subset can contain whatever you want to include, so it can be one or more character and/or environment or props.
    A persona preset is rather new, and it can save one character with all items parented to the character.
    If it is just single character you are using, I think persona preset should be preference.
  • SilverGirlSilverGirl Posts: 3,317
    I have all my characters (with their most common outfits) and common settings saved in different scene subsets, and I File>Merge in whatever I need.
    I now the persona presets exist now, but... well, my system works for me, and I don't particularly feel the need to re-invent the wheel.
  • richardandtracyrichardandtracy Posts: 7,426
    edited June 2025
    I largely do what SilverGirl does.
    When I get a new character, I play about with them, find hair, clothing and jewellery that work with them, apply any morphs, makeup geoshells, tattoos etc. I feel the character needs. After that try various poses to see whether they suit everyday poses or are restricted to 'catwalk model dislocating hip while pretending to be a normal human being doing..' type poses. Then I name the character if the base figure name is still visible and apply a group to the character and all clothes etc.. The grouping allows me to hide the character, eyebrows, clothing and jewellery with a single click on the group, without the group it can take many clicks to completely hide a character. Finally the character gets saved as a scene subset.
    To use the character, I just double click in the character subset in the library and because it's a scene subset, it merges automatically.
    Regards,
    Richard.
    Post edited by richardandtracy on
  • Does Persona Preset help with GPU VRAM memory thing I am struggling with becasue everytime I put 2 or more charcter it lags and gives black renders. I thought maybe I am putting characters wrong or something I tried multiple fix but this black screen always sticks. I saw people putting multiple charcters in the scene and is 8Gb not enough anymore for 8.1? Like even 1 subd everything it cant render. Hiding all the props even walls not enough to render a basic scene. What am I missing I put thresholds went from 2k to FHD, cut the lights, max samples and texture compression to 512, reduce light path lengths nothing fixes it.
    I can't imagine persona preset will save VRAM, as it basically a way to save a character with objects.
    For saving VRAM, check subd level of all the items. Also SBH can be hard on memory.
    You can also use something like https://www.daz3d.com/scene-optimizer
    to reduce texture sizes.
  • jmucchiellojmucchiello Posts: 880
     Nothing saves VRAM except changing the size of textures or lower SubD settings. You should look into getting Scene Optimizer if you are having VRAM issues.
