Anyone know about nice OverSize Shirt for G8F
foxyfoxfurriesfoxyfoxfurries Posts: 391
edited June 2025 in Product Suggestions
Hey , I bought some oversize shirt for G9F and it actually fit to my model but not that much because its not the same genesis , I also searched more simple nice good quality T-Shirt Oversize , Anyone know where can I get one like this? Thanks! ^^
  • tsroemitsroemi Posts: 3,527
    Here, for example: https://www.daz3d.com/dforce-too-big-jersey-for-genesis-9
    Also generally check the stores of lilflame and antje, I'd suggest,
  • Richard HaseltineRichard Haseltine Posts: 109,347
    Please remember that Daz Studio Discussion is for asking about Daz Studio, the application. In-search-of and would-like-someone-to-make threads should go in Product Suggestions, to whiich this one has now been moved.
  • felis said:
    What kind of shirt?
    There is this https://www.daz3d.com/dforce-wet-and-dry-boyfriend-shirt-dress-for-genesis-8-females
     Oh ok sorry about that and thank you! About the shirt I have the dForce Too Big Jersey for Genesis 9 but it fit so bad on G8F , The first one I don't mean like that more like T-SHIRT , Any ways I don't search like you showed me more like in the image below if have , thanks! ^^
    496 x 645 - 539K
  • richardandtracyrichardandtracy Posts: 7,437
    edited June 2025
    Also look at Sveva's stores here and at Renderosity. I have one top that (admittedly is not a traditional Tee) I really like by Lilflame: Asymmetric Shirt. Shown below:
    Regards
    Richard
    Post edited by richardandtracy on
    foxyfoxfurries said:
    felis said:
    What kind of shirt?
    Sorry, I didn't read the thread title correctly, thought you were looking for G9 stuff. Anyway, antje, lilflame and sveva really are your best bet for this kind of thing.
    Regards
    Richard
    SimonJM said:
    Maybe something like dForce Boatneck Tee and Culottes for Genesis 8 Female(s)
    felis said:
    What kind of shirt?
    Hehehehe that's ok :) , and thanks for the shirts you gave me! this two shirts looks more like I searched and will buy them for sure , But I want normal T-SHIRT oversize like I showed , Hope anyone know where can I buy it hehe
  • ElorElor Posts: 3,538
    edited June 2025
    Rhiannon has two normal t-shirts: one here, one on Renderosity.
    https://www.daz3d.com/big-teez-dforce-for-the-g3-and-g8-females
    https://www.renderosity.com/marketplace/products/161834/simple-teez-haunted-for-g881-females
    Another solution if you have the perfect G8 t-shirt (there is a G8 t-shirt currently free for Father Day's on Renderosity maybe it can be a good starting point), you can try a timeline simulation with a standard sized t-shirt:
    • at frame 0, character in base pose, wearing the t-shirt, with the shape you want but with the character scaled at, let's say, 105% for a character scaled at 100% by default (you'll have to tweak to get the best value for what you have in mind).
    • at frame 15, character in base pose at its original scaling
    • at frame 30, character in the final pose (on you have set the final pose at frame 30, you'll likely have to reset the pose at frame 15, and maybe at frame 0).
    And make it a 45 frames simulation, to let 15 frames for the t-shirt to stabilize after the movements related to the change of pose.
    While the character scale will change, as far as I remember, the scaling of the clothes will not, so at the end of the simulation, you'll have a 100% scaled character wearing a 105% scaled t-shirt.
    A timeline simulation could also be a solution to use your dForce G9 t-shirt on Genesis 8, but it's a more complicated process and it may not work perfectly depending on the clothing item used. I can describe the process if you want.
    Post edited by Elor on
  • felisfelis Posts: 6,120
    edited June 2025
    I thought you could take a t-shirt that fully supports dForce, and then set contraction-expansion to something like 120.
    It can work, but has also challenges, as many t-shirts are rather tight from start, and therefore expands odly.
    This is an example of an expanded t-shirt.
    Then I modelled a quick oversized shirt.
    2000 x 1500 - 4M
    2000 x 1500 - 4M
    Post edited by felis on
  • foxyfoxfurriesfoxyfoxfurries Posts: 391
    edited June 2025
    Thanks for the help! I can try it but I really search like this exactly. The Big TeeZ dForce for the G3 and G8 Females may fit but I bought the dForce Boatneck Tee and Culottes for Genesis 8 Female and didn't like it.
    I just want nice simple oversize T-SHIRT with good quality that's all hehe.
    I saw this for example looks really nice but it's not for sale or G8F
    Daz 3D, Marvelous Designer 7 - How To Create A Baggy T-Shirt
    496 x 645 - 539K
    Post edited by foxyfoxfurries on
  • LorraineLorraine Posts: 939
    edited June 2025
    I have this free one and it sims ok...the second morph makes it slightly longer and baggier https://www.renderhub.com/elmenu1/big-shirt-for-genesis-8-female No textures but the body and edges are separate surfaces.
    1000 x 1000 - 581K
    Post edited by Lorraine on
    I will check it out , thank you :)
  • There's also the Oversize Shirt freebie by Mysticartdesign: https://www.deviantart.com/mysticartdesign/art/Oversize-Shirt-900936026
    Thank you I will check it out as well ^^
    edited June 2025
    this one is nice https://3dshards.com/product/dforce-oversized-shirt-for-gf8-gm8-and-g9/ really quick sims and cheap as chips
    1000 x 1000 - 622K
