Show Us Your Bryce Renders Part 13
194969899100
  • mermaid010mermaid010 Posts: 6,113
    Very nice object and beautifully presented Art
  • Fencepost52Fencepost52 Posts: 513
    Thank you smiley
  • HoroHoro Posts: 11,450
    edited June 2025
    mermaid - beautifully done abstract.
    Fencepost52 - that came out excellent Art, great snake-like object.
    Two terrains from High Resolution Terrains 2 with a material from Gritstone Hills and in front of the camera the EWL (extreme wide-angle lens) from Lenses and Filters covers 114° in the diagonal. The clouds are from the CloudSphere8 and the ambient light by the belonging HDRI from the Sky Toolbox, the key light by the sun. A huge boulder of unknown origin in a wide plane.
    Erratic Boulder
    1200 x 800 - 175K
    Post edited by Horo on
    Thank Horo, fantastic scene, the sky is awesome.
    Thank you mermaid.
  • Electro-ElvisElectro-Elvis Posts: 935
    edited June 2025
    Great pictures from everybody.
    I wanted to use two vases from Daz3D. Glass material is from Bill's glass. Light comes from a square dome light and HDRI. Rendertime a few hours, but Antialiasing... an additional 20 hours.
    Two Vases
    900 x 675 - 414K
    Post edited by Electro-Elvis on
  • Bunyip02Bunyip02 Posts: 9,288
    Horo - Wings3D Insect is brilliant ! A huge boulder is wonderful, sky is excellent !
    Mermaid - Two spheres and a cylinder render is splendid !
    Fencepost52 - Snake is amazing !
    Electro-Elvis - Cat tipping over the vase gave me a good laugh, lovely render !
    Thanks Electro-Elvis, fabulous render with the vases, the lighting is fantastic. I think these were a recent freebie. To my disappointment there were no object files.sad
    Bunyip02 thanks.
    Electro-Elvis - very nicely lit indoor scene. Sometimes rendering Premium with 9 or 16 rpp (rays per pixel) is faster than regular. I usually select a critical part and plop-render that part, noting the time and repeat it with another render setting to get an idea what renders faster and look at the difference. I think the square dome light inside a closed room is ideal, if an HDRI is used, the light does not penetrate the walls - except they are set to no shadow casting, or the HDRI has the shadows switched off, or is inside the room but then the room must be positioned so that the HDRI from Inside (at location 0/0/0) is within the room.
    Bunyip02 - thank you
  • HansmarHansmar Posts: 3,165
    Wonderful work, guys and galls. Been holidaying, so wasn't able to check or contribute. But I notice you others are still going strong!
    edited June 2025
    Thanks Hansmar
    The terrain is self-made, the material from Gritty Texture Tiles and matching terrain, and the sky from Advanced Layered Skies
    950 x 535 - 239K
    Post edited by mermaid010 on
  • BurpeeBurpee Posts: 153
    Hi everyone, I was on vacation again but back now.  Thanks for sharing your artwork mermaid, Horo, Elvis and Art.  I'm going to try making an image that isn't an abstract.  Don't want to bore people with my abby spheres.
  • NGartplayNGartplay Posts: 3,403
    Ugh, I logged in as Burpee, my old account from back at Daz Studio 2.
    Also, Past as Future, I like the glass material on your 'hourglass.'
    edited June 2025
    Thanks NGartplay, looking forward to seeing your art
    Thank you Hansmar.
    mermaid - great looking sky.
    Burpee = NGartplay - thank you.
    Thanks Horo
    edited June 2025
    The terrain is from High Resolution Terrains 3 with a material from Landscapes under Fantastic Skies, the water is a self made terrain with a material from High Resolution Terrains 4. The clouds are from the CloudSphere6 and the ambient light by the belonging SkySC6 HDRI from the Sky Toolbox", the key light by the sun.
    Three Peaks isle
    1200 x 800 - 214K
    An outstanding photorealistic scene, Horo, well done.
    Thank you mermaid.
  • NullcastingNullcasting Posts: 43
    edited June 2025
    Hey gang, long time no post. Took a break from art to focus on my mental health. I'm hoping to get back into a groove soon!!
    Here's a mousepad I just finished for myself. Text is from wikipedia (source for their text is cited), and wind turbines are a model by dondon19 on cgtrader.
    Post edited by Nullcasting on
    Nicely done Nullcasting.
    Nice work Nullcasting, the best therapy for mental health is Bryce wink, glad you are feelin better.
    edited June 2025
    The terrain is from Terrain Stacking with a material from the same set. The grass is a self made terrain with a self made material as well, the water is the ground plane again with my own material. Sky and ambient light by an HDRI from High Resolution Terrains 4 and the key light by the sun. A valley in a mountainous region in the moonlight.
    Grassy Pond
    1200 x 800 - 152K
    Superb scene, Horo,  the clouds are awesome
    edited June 2025
    I can't remember if I shared this before; a simple scene using the ShoalofFish Hdri by Horo and a submarine (freebie) viewed thru the GWL.
    mermaid - thank you. Great idea to use this HDRI with the GWL to look through a tunnel to the submarine.
    Thanks Horo
    edited June 2025
    The object in the centre is a Strange Object by Steven Ray, both left and right and above the screen were made in Wings3D. All have a special glassy material consisting of a positive and a negative Hypertexture. Specular from the WhiteSphereB7 HDRI and from the sun in the zenith from which also the light for the shadows comes.
    Object Shadows
    1200 x 800 - 211K
    edited June 2025
    Wow Horo, this render is outstanding, beautifully done.
    I played with this abstract by Alymac (ex ShareCG) I modified the materials and the position of some of the objects. The golden one is Alymac’s example, it’s a fantastic setup, and I'm not sure if I can share the file here. It was a freebie from ShareCG
    750 x 562 - 540K
    640 x 480 - 335K
    mermaid - thank you. This is a great abstract you made from an art work of Alymac (I do not know him/her).
