• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
strange error messiages when importing two different fbx assets into blender 3.6
milliethegreatmilliethegreat Posts: 413
May 2025 in Blender Discussion
I have a bazzare issure with a couple fbx assets into blender. im using blender 3.6 right now.
here are the errors im getting
asset one error message:
TBBmalloc: skip allocation functions replacement in ucrtbase.dll: unknown prologue for function _msize
Read prefs: "C:\Users\rrive\AppData\Roaming\Blender Foundation\Blender\3.6\config\userpref.blend"
FBX version: 7400
ERROR: too much data in this FBX layer, skipping excess!
Traceback (most recent call last):
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\__init__.py", line 207, in execute
    if import_fbx.load(self, context, filepath=path, **keywords) == {'FINISHED'}:
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 3109, in load
    _(); del _
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 3103, in _
    root_helper.build_hierarchy(fbx_tmpl, settings, scene, view_layer)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 2534, in build_hierarchy
    child.build_hierarchy(fbx_tmpl, settings, scene, view_layer)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 2521, in build_hierarchy
    obj = self.build_node_obj(fbx_tmpl, settings)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 2330, in build_node_obj
    blen_read_custom_properties(self.fbx_elem, obj, settings)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_scene_fbx\import_fbx.py", line 316, in blen_read_custom_properties
    assert(fbx_prop.props[1] == b'KString')
AssertionError
asset two error message:
FBX version: 7400
Error, could not find any file path in  FBXElem(id=b'Texture', props=[3036017638768, b'Map #267644\x00\x01Texture', b''], props_type=bytearray(b'LSS'), elems=[FBXElem(id=b'Type', props=[b'TextureVideoClip'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Version', props=[202], props_type=bytearray(b'I'), elems=[]), FBXElem(id=b'TextureName', props=[b'Map #267644\x00\x01Texture'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Properties70', props=[], props_type=bytearray(b''), elems=[FBXElem(id=b'P', props=[b'3dsMax', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDa', b'int', b'Integer', b'', 1858302732], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDb', b'int', b'Integer', b'', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|SuperClassID', b'int', b'Integer', b'', 3088], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|color1', b'Color', b'', b'A', 0.0, 0.0, 0.0], props_type=bytearray(b'SSSSDDD'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1Amount', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1On', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|color2', b'Color', b'', b'A', 1.0, 1.0, 1.0], props_type=bytearray(b'SSSSDDD'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2Amount', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2On', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|type', b'Integer', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|direction', b'Integer', b'', b'A', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|node', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|mtlIOROverride', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|ior', b'Float', b'', b'A', 1.600000023841858], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|extrapolateOn', b'Bool', b'', b'A', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|nearDistance', b'Float', b'', b'A', 0.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|farDistance', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|mix curve', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[])]), FBXElem(id=b'Media', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'FileName', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'RelativeFilename', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'ModelUVTranslation', props=[0.0, 0.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'ModelUVScaling', props=[1.0, 1.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'Texture_Alpha_Source', props=[b'None'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Cropping', props=[0, 0, 0, 0], props_type=bytearray(b'IIII'), elems=[])])
       Falling back to:  Map #267644
Error, could not find any file path in  FBXElem(id=b'Texture', props=[3036017633488, b'Map #267645\x00\x01Texture', b''], props_type=bytearray(b'LSS'), elems=[FBXElem(id=b'Type', props=[b'TextureVideoClip'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Version', props=[202], props_type=bytearray(b'I'), elems=[]), FBXElem(id=b'TextureName', props=[b'Map #267645\x00\x01Texture'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Properties70', props=[], props_type=bytearray(b''), elems=[FBXElem(id=b'P', props=[b'3dsMax', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDa', b'int', b'Integer', b'', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDb', b'int', b'Integer', b'', 675561916], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|SuperClassID', b'int', b'Integer', b'', 3088], props_type=bytearray(b'SSSSI'), elems=[])]), FBXElem(id=b'Media', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'FileName', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'RelativeFilename', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'ModelUVTranslation', props=[0.0, 0.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'ModelUVScaling', props=[1.0, 1.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'Texture_Alpha_Source', props=[b'None'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Cropping', props=[0, 0, 0, 0], props_type=bytearray(b'IIII'), elems=[])])
       Falling back to:  Map #267645
Error, could not find any file path in  FBXElem(id=b'Texture', props=[3039286641408, b'Map #267481\x00\x01Texture', b''], props_type=bytearray(b'LSS'), elems=[FBXElem(id=b'Type', props=[b'TextureVideoClip'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Version', props=[202], props_type=bytearray(b'I'), elems=[]), FBXElem(id=b'TextureName', props=[b'Map #267481\x00\x01Texture'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Properties70', props=[], props_type=bytearray(b''), elems=[FBXElem(id=b'P', props=[b'3dsMax', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDa', b'int', b'Integer', b'', 1858302732], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|ClassIDb', b'int', b'Integer', b'', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|SuperClassID', b'int', b'Integer', b'', 3088], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|color1', b'Color', b'', b'A', 0.7647059559822083, 0.7647059559822083, 0.7647059559822083], props_type=bytearray(b'SSSSDDD'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1Amount', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map1On', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|color2', b'Color', b'', b'A', 1.0, 1.0, 1.0], props_type=bytearray(b'SSSSDDD'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2Amount', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|map2On', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|type', b'Integer', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|direction', b'Integer', b'', b'A', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|node', b'Reference', b'', b'A'], props_type=bytearray(b'SSSS'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|mtlIOROverride', b'Bool', b'', b'A', 1], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|ior', b'Float', b'', b'A', 1.600000023841858], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|extrapolateOn', b'Bool', b'', b'A', 0], props_type=bytearray(b'SSSSI'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|nearDistance', b'Float', b'', b'A', 0.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|parameters|farDistance', b'Float', b'', b'A', 100.0], props_type=bytearray(b'SSSSF'), elems=[]), FBXElem(id=b'P', props=[b'3dsMax|mix curve', b'Compound', b'', b''], props_type=bytearray(b'SSSS'), elems=[])]), FBXElem(id=b'Media', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'FileName', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'RelativeFilename', props=[b''], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'ModelUVTranslation', props=[0.0, 0.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'ModelUVScaling', props=[1.0, 1.0], props_type=bytearray(b'DD'), elems=[]), FBXElem(id=b'Texture_Alpha_Source', props=[b'None'], props_type=bytearray(b'S'), elems=[]), FBXElem(id=b'Cropping', props=[0, 0, 0, 0], props_type=bytearray(b'IIII'), elems=[])])
       Falling back to:  Map #267481
    _(); del _
AssertionError
how the heck to i fix this? is it even fixable?
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,239
    May 2025
    @milliethegreat
    Why are you using such an old version of Blender? You are asking for things like what you are experiencing. This is not DAZ and you can easily run multiple versions of Blender side by side and revert if you choose to. No reason to not be using 4.4. The FBX importer seems better, though I don't use it often.
    Second, since FBX is proprietary, the Blender guys had to essentially reverse engineer it, and so it never worked robustly. But there is an addon called Better FBX Import which is preciselt that. It might work better for you.
  • milliethegreatmilliethegreat Posts: 413
    May 2025
    TheMysteryIsThePoint said:
    @milliethegreat
    I use the old version of blender because when I import posed Daz figures into the newer versions it either doesn't import the poses right or any attached props don't import attached to the characters. I use diffeomporphic because some objects have emissives. Also how expensive is that plugin? If it's not anything crazy price it's probably worth a try. I don't want to spend bookoo amounts of money if it turns out not to be what i need after all.
    May 2025
    Also I believe I tried 4.4 as well. Same results
    May 2025
    If you are having issues with diffeomorphic, an open source project, the best option is to engage a little bit and send Thomas a bug report. Include exactly what you did, what you expected the results to be, and what the actual results were. You'll find that he's an amazing developer and fixes things with supernatural speed... if... You give him what he needs in order to help you. He wants Diffeo to work well as much as you do. As for the plugin: https://superhivemarket.com/products/better-fbx-importer--exporter?ref
    June 2025
    I actually got better fbx exporter and it definitely solved the issue I was having with the error messages i mentioned. I got the assets to import into blender with zero issues and i exported the assets from blender into Daz as obj afterwards just fine too. That's one major problem solved. I'll count that as a win! Thanks for the suggestion on the plugin!
    June 2025
    I'm ecstatic at hearing that! We really have to take the wins where we find them :)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
