• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic Add-ons Version 5.0.0 Released
«1234»
  • brainmuffinbrainmuffin Posts: 1,276
    May 2025
    I figured it out. Hair seems to have an issue rendering though. It shows in the Layout window on Blender.
  • PadonePadone Posts: 4,053
    May 2025
    @brainmuffin The istallation is the same as diffeomorphic is a script. Blender doesn't render polylines, so you have to convert to curves, eventually using the hair tools.
  • riuken1riuken1 Posts: 157
    May 2025 edited May 2025
    Padone said:
    The 4.4 addon works fine with blender 3.x 4.x
    Thanks I install the addon and all is working fine, I was wondereing if is any way to  show only the 1 thumbnail of daz files, for example wen we are looking for poses, it show the files and 2 additional thumbnails. Any way I use this YT tutorial, it have  the info on how intall and use the the addon.
    Post edited by riuken1 on May 2025
    May 2025
    Is the hair conversion after pulling into Blender?
    May 2025
    @brainmuffin
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Hair Tools
    May 2025
    Padone said:
    @brainmuffin
    Thanks. I'll take a look.
  • phimetaversephimetaverse Posts: 11
    August 2025
    Hi, on the newest diffeomorphic, how do we enable the rigged tongue? It stopped working for me a while back and no new versions have fixed it. I've also used blender 4.3, 4.4 & 4.5. Thanks
    August 2025
    diffeomorphic 4.5.0.0147, blender 4.5.1
    Works fine here, you have to select the IK option for the tongue in the MHX panel when you generate the rig, then activate the Head layer. Be sure to update both "import_daz" and "mhx_rts".
    https://bitbucket.org/Diffeomorphic/workspace/projects/DIF
    320 x 184 - 12K
  • Singular3DSingular3D Posts: 626
    August 2025
    So great to see the new version!
    Thanks a lot to Thomas !!!
  • rojharrisrojharris Posts: 18
    August 2025 edited August 2025
    Hi. When I import a Gen 9 character I get lots of Python errors when on the Mac. I don't get any morphs imported either (I am using the Gen 9 preset). When I try with Gen 8 everything works fine. When I try this on the PC everything works fine. I'm using latest 4.5 stable and latest blender 4.5.1 LTS.
    I've tried removing scripts & addons and re-installing but cannot get it to work. All DAZ content is installed via DIM and root dirs set up properly.
    Could there be some cached/hidden files left over that I'm not removing before a re-install? I'm at a loss to know what to try. The errors are python tracebacks and I can work around the morph issue by importing them afterwards but I'm not sure what else my be broken broken. I don't want to work on the PC as it's old and has a limited content install, so I'd like to get it working on the mac.
    UPDATE: Well, I went through all my DAZ and Blender folders in my ~Library and deleted everything to do with Diffeomorphic. Then downloaded the latest dev build and installed that, as well as the scripts and Whoop-de-Doop! It's working perfectly.. There was some old stuff from 2022 in there so I guess that was the issue.
    Cheers
    Post edited by rojharris on August 2025
    August 2025
    hi! so the tongue rig still doesnt work, and im now getting this error at the bottom of the screen when i try to use the drivers. im using both recommended versions of blender and diffeomorphic. can someone help me please?
    1920 x 1080 - 654K
    To "use the drivers" you have to go to the runtime tab, where you find the loaded morphs, you can't edit the shapekeys directly. For the G9 tongue you have to enable the custom layer in the blender bone collections, this happens because for G9 the mouth is a separate figure in daz studio.
    333 x 330 - 32K
    Post edited by Padone on August 2025
    August 2025
    Please could you show me how to do this? I'm having a hard time finding both things & unsure what to do. Thanks :)
    August 2025
    Managed to fix the tongue but not the drivers, thanks in advance!
  • MrRogerSmithMrRogerSmith Posts: 129
    November 2025 edited November 2025
    I'm trying to add IK to the diffeomorphic rig (not the MHX or Rigify rigs).  I've seen several videos showing an option to "add simple IK" under the rigging tab.  But that option isn't showing for me.  Is this feature no longer available in the current version of Diffeo?
    EDIT: I fixed it.  "Simple IK Tools" has to be enabled in the preferences for the add-on.
    430 x 742 - 71K
    Post edited by MrRogerSmith on November 2025
  • 1841180318411803 Posts: 2
    December 2025
    Have the DAZ facial expression "controllers" stopped working when imported into Blender 4.5–5.0? They used to work fine before, but now after importing into Blender, when I select the model with the facial expression controllers and click Finishing - Convert To Widgets, the controllers disappear immediately. After completing the MHX conversion for all bones, there are no facial expression controllers in the MHX layers either. We can only adjust expressions by dragging shape keys, which is extremely cumbersome.
    Could we add the function of linking facial expression controllers to shape keys to this plugin? That would make it perfect. Will this be implemented in the future? I’m not sure, but I hope so. Thank you so much for your efforts!
  • ThomasLarssonThomasLarsson Posts: 98
    December 2025 edited December 2025
    Version 5.0.0 has been released. It is compatible with Blender versions 3.0 - 5.0.
    DAZ Importer:
    https://www.dropbox.com/scl/fi/8b5z3cy6kd9pcxeo17bh1/import_daz-5.0.0.zip?rlkey=udvj5mbw4f1psmvrnt8949ed5
    MHX Runtime System:
    https://www.dropbox.com/scl/fi/0nf018loxjpy0nbe26zpr/mhx_rts-5.0.0.zip?rlkey=dd33350oazwagkund3puqt7up
    BVH and FBX Retargeter:
    https://www.dropbox.com/scl/fi/0ftrenp005ub78ov5fek0/retarget_bvh-5.0.0.zip?rlkey=c27jhf4pxc3scpu0ffmil197d
    Post edited by ThomasLarsson on December 2025
    December 2025
    DAZ Importer:
    MHX Runtime System:
    Thanks a lot! This is very helpful and appreciated!
  • Rufus CoppertopRufus Coppertop Posts: 178
    December 2025
    Doesn't work. Apparently the mesh is "set to DBZ".
    the thing is the DBZ button is not checked when I go to global settings. checking the button, trying again then unchecking and trying again doesn't work.
    1250 x 643 - 39K
    December 2025
    You need to export the dbz in daz studio, by running the daz script provided with the distribution. The dbz file must be saved with the same name in the same folder as the daz scene.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Export from DAZ Studio
    December 2025
    Daz saves it asa dbz.duf and Blender simply will not recognize it. I cannot seem to make it work and it's doing my head in.
    Any other advice will be very gratefully received.
    December 2025
    I got it working!
    Yes oh yes! I got it working. By the Living Harry I got it working!
    December 2025
    It's working!
    January 11
    where can I find the driver editor please? whenever I apply a shapekey it gives me this message:
    452 x 129 - 26K
    January 12
    You can't edit the shapekeys values by hand because they are driven, removing the drivers will break the rig. If you don't want to import the armature then you can uncheck the armature option in the global settings.
  • GolaMGolaM Posts: 120
    January 14
    I recently switched to blender 5 and the new version of diffeomorhpic and noticed that quite a few segments in "DAZ Setup" are missing, like the Simulation part. Is this a bug on my installation? Temporary removed parts? Or are those tools permanently gone?
    January 15
    Be sure to anable all the features in the addon preferences.
    edit > preferences > addons > daz importer > features
    January 15
    Thank you, that solved it. Much appreciated heart
    January 27
    DAZ Importer:
    MHX Runtime System:
    Thank you very much for all your work on this!
  • w.dereck2001w.dereck2001 Posts: 0
    February 1
    Hi, so I have never posted here, I'm sorry if I'm doing it the wrong way. I have a question with hairs, so I'm importing a Genesis 9 with hair, the figure doesn't seem to have any problems, but the hair looks black like it has no texture nor shader. The mesh looks fine, and the rest of the figure looks fine too, but I can't find the solution to the hair, if anybody has an advice, it would be great. Thanks in advanced.
    1910 x 990 - 900K
«1234»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
