UltraScatter2 - Now in store!
24567
  • ArtiniArtini Posts: 10,413
    Very nice, @AnEye4Art
    Now you can use the possibilities of your computer hardware to the max.
  • ImagoImago Posts: 5,686
    Artini said:
    Oh, yes, so much fun.
    Another simple example....
    Can you animate those spaceships? Make them travel along the surface of the planet keeping their altitude and angle from the planet's soil?
    Interesting question, @Imago
    I have no idea, how to do it in Daz Studio.
    The plugin itself should have that kind of option, since it's a complex opreation otherwise.
    If it can't animate stuff along the surfaces, like swarming ants or rolling marbles, it sadly adds nothing to the previous version.
  • AnEye4ArtAnEye4Art Posts: 860
    I am really enjoying pushing ultrascatter2, and so far it delivers.
    2500 x 1000 - 4M
    edited May 2025
    Agree. I am addicted to UltraScatter2 and looking forward to using it all the time.
    The best of the best tool for Daz Studio.
    https://www.daz3d.com/gallery/user/5383823743254528#gallery=newest&page=1&image=1370621
    1920 x 1080 - 534K
    Post edited by Artini on
    I had to get a better computer and I'm glad that I did. Because creating demanding, high-poly scenes are a lot easier.
  • Richard HaseltineRichard Haseltine Posts: 108,817
    Gallery image links expire, please uplod thje image as an attachment to your post (you can link to the gallery page itself if it has been published, but not as an image link).
    Thanks, @Richard
    I have edited my post.
    Good job, Artini. I like the entire scene, but mostly the mixed vegetation. Ultrascatter2's layering ability is a great addition that I plan on using a lot more of.
    edited May 2025
    Maybe this is possible already, but the ability to save an ultrascenery file to use in ultrascatter2, then open it, edit the layers, and scatter. Imagine the endless possibilities!!
    Post edited by AnEye4Art on
    edited May 2025
    Thanks, @AnEye4Art
    Have tried to scatter some cows, again.
    1920 x 1080 - 653K
    Nice work, Artini.
    Thank you, @AnEye4Art
    Have anybody tried custom Image Map to limit scattering of instances to selected white areas on the map.
    I have tried, but cannot figure out what mapping is used.
    In UltraScenery2 I have just made a top view render of the terrain generated,
    painted in the Gimp white areas, where I wanted the instances to be generated,
    then inverted the selection of the whites and filled the rest with black.
    UltraScatter2 behaves differently.
    I used a black and white splatmap to isolate where I want to limit the scatter. I invert it to get the scatter in the white areas. But otherwise it works for me.
  • HowieFarkesHowieFarkes Posts: 624
    That should still work in UltraScatter2 - but maybe you might need to change the Image Map projection to "Y (top/bottom)" to force a top down projection.
    Thanks for the tips. I will try that.
    edited May 2025
    I am curious if it'll work for you.
  • stem_athomestem_athome Posts: 526
    edited May 2025
    HowieFarkes said:
    MelanieL said:
    I almost hate to ask, but: Does it work in DS4.21.0.5 or does it need a newer version? (I have UltraSceneryXT and USC2 and both of those work there).
    It should*
    *although I haven't tested on older versions but I'm not using any new features so should almost work back to 4.5
     Hi,
    I tried to use this in DS 4.10, but it crashed.
    So I tried using DS 4.22, although it worked, when going down the scatter options, it does not show what the option are. Have attached a screen grab.
    Just tried ds 4.24. Same problem, options not named. Running DS on win11.
    OK, my bad with the later versions, I did not copy the help files over, and the plugin is taking the text for the options from there.
    520 x 902 - 23K
    Post edited by stem_athome on
    Yes, it works when I change the Image Map projection to "Y (top/bottom)" to force a top down projection,
    as @HowieFarkes suggested. I will make more tests and will post some results, when I will get more time.
    edited May 2025
    Have put some birds on to the hand sculpture.
    Any idea about how to limit orientation of the birds to mostly horizontal and not the upside down?
    1200 x 1080 - 393K
    I'm not an expert, but unwrap the hand and paint the mask on it in gimp or Photo shop to get the birds where you want them?
    Thanks for the advice. Have to try.
    edited May 2025
    In the meantime another experiment with UltraScatter2:
    Centaur and Butterflies
    Used:
    https://www.daz3d.com/nessus-hd-for-centaur-7-male
    https://www.daz3d.com/little-butterfly
    1200 x 1080 - 484K
    Nice.
    Thanks.
    I think, probably I need to paint a map over UV mapping of the object.
    edited May 2025
    I have made just simple map over top down view of Mr Rubble, but it does not work.
    1200 x 1080 - 410K
    edited May 2025
    Finally got it.
    1200 x 1080 - 370K
    Use the Slope distribution modifier. Set "Min" to 0 and "Max" to 30 and work from there. Much easier than playing around with making an image map,
    Thanks. @HowieFarkes
    I have figured it myself and applied it to my previous image.
    Image maps works for me only for simple objects, like Daz Studio primitives.
