"G8 Character Turns White in 3Delight – Texture Not Displaying
My DAZ version is 4.24, and I bought a G8 model. It works fine with Iray rendering, but it doesn't render correctly with 3Delight. When I try to render using 3Delight, the character turns white and the textures don't show up. So, I’d like to know if there’s any simple way to make the model’s textures appear correctly in 3Delight. Thank you.
I can render other models using 3Delight, but this particular model doesn't work. So, I think the issue is with her skin texture. Is there a way to make her render correctly in 3Delight without changing her skin texture?
  • GhostofMacbethGhostofMacbeth Posts: 1,772
    When you go to the skin shader (pick a part like the torso or arm) what does it say at the top of the surface panel?
  • siyaoli84siyaoli84 Posts: 27
    GhostofMacbeth说道:
    当您转到皮肤着色器(选择躯干或手臂等部分)时,表面面板顶部会显示什么?
    PBRSkin MDL
    1287 x 830 - 156K
    There is a way to do it. Do you know which of the 3DL shaders you like? (AoA, Uber, 3Delight default are some options)
    But you can find a figure that you like and Control click on that and there will be a dialog that pops up. It should say something about replacing images and you say no. They you will have the other shader with the new skins. You can adjust it after that.
