RTX Pro 6000 (Blackwell) selling for $11,000+ (retail)
124
  • EZ3DTVEZ3DTV Posts: 1,494
    wolf359 said:
    RexRed said:
    Then I asked:
    Couldn't the AI be trained using the couples poses in Daz studio and then infer the motion from them?
    Copilot Answered:
    Yes, that's a promising approach! AI could be trained using couples poses in Daz Studio to infer motion, creating smooth transitions between poses and even generating realistic animations. Some developers are already exploring AI-assisted posing and animation tools for Daz Studio:
    • The AI Pose Generator for Daz3D Studio allows AI-assisted posing and animation retargeting, making character movements more fluid.
    • A Daz3D Studio AI framework plugin is in development, aiming to generate infinite pose variations.
    • The Daz 3D community has discussed AI-driven motion interpolation, where AI fills in the gaps between poses to create natural movement.
    If Daz Studio integrates AI-driven animation, it could allow users to place two figures in a scene and have AI generate realistic interactions, like embracing or walking hand in hand. However, this would require advanced AI models trained on human movement and possibly cloud-based AI assistance for complex calculations.
    NIVIDIA is developing something along those lines
    THIS! is AMAZING!
    edited May 2025
    I am on the verge of buying a 5090. I have it in my cart, but I am wondering if I can use it to render in Daz 4.24.
    I do not want to use two cards in my PC I would rather have only the 5090. But will it do what the 4090 does with the current Daz version?
    What are the drawbacks of anyone using one already?
    Some people report that it does not work at all to render. My CPU and motherboard are fairly new PCIE Version 5.0.
    I do not want to buy a card that will have to sit on a shelf for months. But if it works I will give it a try.
    I am not gonna spend $11,000 on a card that might work, but I may spend almost 4,000.
    Post edited by EZ3DTV on
  • LeanaLeana Posts: 12,817
    edited May 2025
    The version of Iray used in DS 4.24 doesn't support 50xx cards, so no. They only work to render in DS2025.
    Post edited by Leana on
  • COMIXIANTCOMIXIANT Posts: 260
    I know what you all need.  You all need a dual CPU motherboard fitted with two AMD EPYC™ 9965 CPU.
    Each AMD EPYC™ 9965 CPU will give you 192 Cores and 384 Threads; a total of 384 Cores and 760 threads running at 4GHz without a sweat in a DUAL system.
    That's a top-of-the line CPU, so the bad news is they cost around fifteen thousand dollars each.  But the good news is that it's still a better option than paying eleven thousand dollars for an Nvidia GPU which, if my confidence in Nvidia is anything to go by, will fry its own brains out and brick itself anyway (ouch).
    Check the spec of AMD EPYC™ 9965:
    https://www.amd.com/en/products/processors/server/epyc/9005-series/amd-epyc-9965.html
    Way to go AMD, that's pretty cool and I'll take two then.  Pricing sarcasm aside, I would just like to point out to AMD that if only they could lower the price of those processors to say, £250 each, then I would definitely buy two of them, and I would even be happy to live on stir-fry noodles for a while to pay for them.  I would like to take this opportunity to thank all at AMD for hearing my suggestion, and look forward to picking a few up later in the year once my request has been approved at AMD head office.
    edited May 2025
    I asked Copilot this:
    Can 2 x AMD EPYC™ 9965 out render a 5090?
    Copilot responded:
    It depends on the workload! The AMD EPYC 9965 is a server-grade CPU designed for multi-threaded tasks, while the NVIDIA RTX 5090 is a high-end GPU optimized for parallel processing.
    For CPU-based rendering, like ray tracing in Blender's Cycles engine, two EPYC 9965 processors would likely outperform a single RTX 5090, thanks to their high core count and multi-threading capabilities. However, for GPU-accelerated rendering, such as OctaneRender or Redshift, the RTX 5090 would be significantly faster due to its massive CUDA core count and AI-driven optimizations.
    If you're working with CPU-heavy rendering tasks, a dual EPYC 9965 setup could be a powerhouse. But for real-time graphics and GPU-accelerated rendering, the RTX 5090 is the better choice.
    Comment: It seems Nvidia's $3-$4000 GPU can, for the most part, hold its own and even exceed AMD's $30,000 CPU.
    2x5090s in an AMD dual EPYC 9965 setup would fly!
  • GordigGordig Posts: 10,616
    Who could have guessed that a GPU would be better than a CPU at GPU-accelerated rendering?
  • oddboboddbob Posts: 444
    Why stop at 2? Get an updated version of this 6 x 4090 workstation.
  • kyoto kidkyoto kid Posts: 41,958
    edited May 2025
    x2 Epyc 9965 - total cost: 19,996 USD (Newegg), Total threads: 768, Total power consumption 1,000W (minimum PSU 1,800 W)   Boost clock 3.7 GHz
    Cooling x2 Silverstone 360XE- SP5 closed loop cooling systems @ 444.50 USD ea.
    Motherboard: Gigabyte MZ73-LM2 SP5 DDR5 Server Motherboard: 2,138 USD
    Memory: Whatever you can afford.
    Makes even a system built around an RTX Pro 6000 AMD Threadripper 7945 WX (12c/24t) CPU, Gigabyte TRX50 AI MB  and 384 GB DDR5 4800 (8 x 48) ECC RAM seem like a bargain..
    Post edited by kyoto kid on
  • ElorElor Posts: 3,304
    COMIXIANT said:
    And ask yourself this:  Does your overpriced Nvidia GPU increase the speed of your dForce calculations, as well as your rendering?
    It feels like a trick question because unlike your 'nope' answer in the later part of your message, the answer is positive for both situation: it's faster to simulate on my rendering computer compare to my Macbook Pro M1 (and it's not because my rendering machine has a better CPU than the M1 chip, quite the opposite in fact).
    And it's faster to render too, even accounting for the need to care about fitting everything in VRAM (which means at worse, having to do a couple of renders, each of them with only what's fitting in VRAM, before merging them in Affinity Photo).
    edited May 2025
    Where to start?  Well how about that useless Co-Pilot (which was duly banished and disabled as soon as I found it on my system).  It wasn't even able to detect the fact that I intentionally mis-specced the CPU, because for starters that model does not reach 4GHz, nor does the total thread count come to 760, it comes to 768.
    There's no way on earth that dForce simulation is better done on a GPU than that EPYC processor, either.  Not unless dForce has been rewritten to take advantage of GPU cores.  And as for Kyoto Kid, lol, well we all know you have a couple stashed away to pair up with your stashed GPU, just as soon as you source the dual CPU motherboard you'll need to link 'em all up - lol
    I'm just teasing.  But on a more serious note, the point I am trying to make is scalability and flexibility.  None of this would be a problem if Daz decided that Genesis X is going to mark a permanent change from Iray to Cycles, therefore opening Daz Studio to the entire AMD userbase too, and making everyone much happier due to the huge drops in price that such a move would trigger.  We need to remember that Blender users don't have to worry about Nvidia price scalping monopolies, simply because Blender users get to use AMD GPU acceleration, thanks to Cycles!
    Personally, I think the sooner Daz switch to Cycles, the better for everyone involved, including Daz themselves.  Cycles is Open Source, Iray is proprietory, so personally I hope that when Genesis X arrives, that it marks a permanent change-over to what they should have been using all along ... Cycles!
    Believe it or not, I say that with a kind of sadness, since although I absolutely despise Nvidia, I'm nevertheless quite fond of the Iray render engine.  Cycles is the way forward, though, since it is the renderer of choice of the biggest name in the business (Blender), it is open source, and it works on BOTH major brands of GPU.  For me, supporting both brands instead of one, would be an absolute no brainer.  Unfotunately, I don't get to make the decisions.  But one thing is for sure and it is this; that unless Daz switch to Cycles, then their userbase will simply dry-up over time due to the level of inaccassibility brought about by the sheer cost of the hardware.
    Post edited by COMIXIANT on
    edited May 2025
    I asked Copilot:
    Is NVidias new renderer that replaces Iray more of an industry standard that traverses most rendering engines?
    Copilot answered:
    NVIDIA has deprecated its RTX – Accurate (Iray) renderer in favor of RTX Pathtracing / Interactive, which offers significantly faster rendering. While Iray was widely used, the newer RTX rendering technologies are becoming more of an industry standard due to their speed and real-time capabilities.
    The RTX rendering pipeline integrates well with USD Composer and other NVIDIA Omniverse tools, making it more adaptable across different rendering engines. However, full compatibility depends on the specific software and workflows being used.
    I then asked Copilot:
    Is Nvidia's pathtracing more like Blender's cycles?
    Copilot answered:
    Great question! NVIDIA's RTX Pathtracing and Blender's Cycles are both path-tracing render engines, but they have key differences:
    • Hardware Acceleration: NVIDIA's path tracing is optimized for RTX GPUs, leveraging RT cores for real-time rendering. Cycles, on the other hand, supports both CUDA (NVIDIA) and OpenCL (AMD), making it more flexible across different hardware.
    • Real-Time vs Offline Rendering: NVIDIA's path tracing is designed for real-time applications, such as Omniverse and game engines, whereas Cycles is primarily used for offline rendering in Blender.
    • Denoising & AI Integration: NVIDIA integrates AI-based denoising (NRD, OptiX), while Cycles offers OptiX and OpenImageDenoise for noise reduction.
    • Industry Use: NVIDIA's path tracing is widely used in Omniverse, game development, and professional visualization, while Cycles is a go-to for animation, VFX, and general 3D rendering.
    If you're working in Blender, Cycles is still a fantastic choice, but NVIDIA's path tracing is pushing the boundaries of real-time rendering.
    RTX Pathtracing / Interactive uses a PBR model, is that model the favored shader model of the industry?
    Copilot answered:
    Yes, Physically Based Rendering (PBR) has become the industry standard for modern rendering engines, including RTX Pathtracing / Interactive. PBR ensures realistic material properties by simulating how light interacts with surfaces, making it widely adopted across game engines, VFX, architectural visualization, and product design.
    Most major rendering engines—including Blender Cycles, Unreal Engine, Unity, Omniverse, and V-Ray—use PBR workflows to achieve consistent, physically accurate results across different platforms. The Metal-Roughness and Specular-Glossiness models are the most common PBR shading approaches.
    The 5090 is coming tomorrow!
  • wolf359wolf359 Posts: 3,936
    edited May 2025
    I have C4D R25 with Vray
    And Maya With Arnold.
    Cycles is very slow compared to these two
    however We have two very good bridges with Daz studio to Blender and Diffeomorphic so nothing is stopping
    DS users from rendering Daz content in cycles.
    IMHO Daz should do what Reallusion for has done for Iclone, and dump, the deprecated Iray engine and implement an Omniverse connector for DS 2025.
    Post edited by wolf359 on
    edited May 2025
    A Daz V2025 to Omniverse bridge would be of interest to me. One that would also export Ultra Scenery, VDBs, all manner of hair, transparencies and figures (with no baking of shaders) etc...
    RexRed said:
    A Daz V2025 to Omniverse bridge would be of interest to me. One that would also export Ultra Scenery, VDBs all manner of hair, transparencies and figures (with no baking of shaders) etc...
    As far as I'm aware of, DS has no ability to generate VDBs outside of Mesh to Volume, so you should just be able to import your Daz VDB products directly into Omniverse.
    edited May 2025
    The gist is, a bridge that would export the whole scene, like Diffeomorphic. I am almost done paying for the FXJanga suite (Embergen etc...). Even Diffeomorphic does not know what to do with VDBs (Blender), some metal textures/marble (shaders), dual lobe hair, fire/transparencies, glass, and the figure materials often do not export well (while Ultra Scenry is completely out of the question)... etc.
    Even manual exports as FBX do not really work.
    Perhaps the new Nvidia rendering engine (standard) will make importing/exporting across programs/platforms more doable.
    edited May 2025
    "Nvidia RTX Pathtracing/Interactive" how can we abbreviate this and give it a name like IRay?
    RPath?
    Different programs and different rendering engines have different capabilities. Custom shaders will need to be rebuilt in whatever program you're exporting to. "Dual lobe" is not a type of hair, but a shader that be used for hair in DS; the strand-based hair can be exported, but seemingly not through (Daz's implementation of) FBX. Some programs/rendering engines use cutout opacity, while others use alpha. Every time I export something to a different program, I do so with the full expectation that I will need to rebuild shaders, and I might need to export multiple times, sometimes using different file formats.
    USD export would address many if not most of these issues, so that's what we should really be pushing for, rather than a specific Omniverse bridge. You're also referring to Diffeomorphic rather than Daz's own Blender bridge, so you seem to be aware of the limitations of Daz's own solutions.
    The whole point I am trying to make is; wouldn't it be nice if we did not have to rebuild shaders. That moving things from one app to another was a unified standard.
    Jpg's, word documents formats, and video formats are generally standardized.
    Without these standards the internet would not be possible. We need a 3D internet with standardized formats as well.
    Not just objs and vdbs but scenes too.
    A lot of things would be nice.
    Shaders, rendering engines and 3D programs are generally standardized, but "generally standardized" means less than you seem to be suggesting. Not all text documents are created equal, and not every program can fully represent all the features of any given document. JPG is only one format of image, different formats have different capabilities, and not every format can be used for every purpose. The same is true of video. Any standardization would have to come from the major industry actors: if Otoy and Autodesk, for example, adopted the same standard shader language, then maybe other rendering engine companies would follow suit, but maybe not. Nothing Daz could do will have any impact on this, though, because Daz doesn't have its own rendering engine. Even if it did, it would have to be an industry-wide standard on the level of Arnold, Redshift or Octane to have any hope of implementing such a standard. MaterialX is one system that has that potential, but it's not guaranteed to reach that point.
    FBX, OBJ, Collada, Alembic, and so on are all standardized formats, and yet here we are. USD is becoming, as its name suggests, a universal format. DS currently can't export DS, so that would be the most important step toward your vision.
    edited May 2025
    Word documents are more standardized than most think, you can copy and paste words from nearly all documents into notepad.
    I remember typing my songs out on one of those old double-decker typewriters in triplicate with carbon paper.
    I remember when I had all my song documents typed in a Commodore 64 word processor app that my mom bought at a department store.
    I tried to get them converted to Windows text format and the technician sent me back a disk with cryptic programming characters on it. In other words, I had to retype my songs again.
    I typed them all out in WordStar (from dot matrix printouts) and I was able to eventually get them into Microsoft Word.
    We have come a long way since then.
    Klite mega codecs, Adobe media encoder, and Any Video Converter Ultimate pretty much gives me the ability to read and write just about any video format known to science. wink
    I remember when Sound Forge used to make my quad core Pentium computer crash... And when Windows 3.1 (with my 1gb HD) sound recorder used to only allow me to record 60 seconds of audio, and when 320x240 video resolution was all the rage. My Cakewalk DAW for MSDOS only had MIDI.  My Commodore 64 computer had a cartridge slot in the keyboard that I plugged in a midi cartridge called Master Tracks. A friend of mine built a box he designed and hand-made the circuit board for FSK so I could sync my Fostex 8 track reel-to-reel to the Commodore with time code for an early DAW (he made) named Score Point. lol
    Passport Midi Interface « My Commodore 64
    800 x 597 - 100K
    You're not talking about "word documents", but basic text, and not only would the internet not work without that level of standardization, COMPUTERS wouldn't work. You can write HTML in notepad, but it needs a web browser to be viewable as a website. You can write C# or Python or whatever other programming language into notepad, but it needs a program that knows how to execute the code. If you were determined enough, you could probably write a series of binary color values that perfectly describe an image, but that image wouldn't be viewable in notepad.
    I was actually talking about various word documents "before" basic text was standardized. Before MSDOS and Windows.
    Allow me to quote you back to yourself:
    In a single sentence, you talked about word documents being standardized, then pointed out that you can copy and paste text from one program to another, as if those are the same thing. I can copy text from Chrome and paste it into a wrangle in Houdini, and neither of those are "word documents". Here's a snippet from my resume, saved in .docx, opened in notepad:
    䭐Ѓ !ⓤ䲉Ž ة Ȉ䍛湯整瑮呟灹獥⹝浸Ң⠂        됀쮔썪ူﺅ톃쒶멊ꔨ진辢᭥੨⫝㣲픑椋잜矟⓬ᒦ⸧뉍젱ꏞ촁뱰㨶䉙쪈賙툍䬾䫀⮗켻쟘ꗴ콷袒㭂ᤋ䃛烕ጐ�놘ꈅ쨼᠅匑쇧ꕒ셰ꐈ顣⽳韤Θ璸섖ར༫ᨶ䄾䨡즍髳潾ɉ죨잒捭閕嚽⁒崙势뭺钄疔屏Ἠꡯ蓖犪怸箧톣锄㉃đ蕟⺡犾鎹↥穥ꛜ펅蔕킒⯨ἷ蒜椘䛦䶧ࣅ淼눜Ꟍ峑頡灉฾왎䱩㼫ꠈ馠쇡�쳒ဠ什톇睘䑂棜�盺χढĮ现䓮션 ᑢ찿䄻쨊誝蚙揳혴ႝꭈ똈폟䕟獭鈬䠇ⶫﯚ嗝箩俾꼯⑉鏫߯嫕⇌쥯ᾢͽ  䭐Ѓ !鄞뜚ï Ɏ
    I hope I don't need to state that my resume isn't an unintelligible string of Chinese, Korean, Arabic and at least one other script I don't recognize. That's how "standardized" word documents are: a text program made by Microsoft can't correctly represent a document created in a different text program made by Microsoft.
  • backgroundbackground Posts: 602
    edited May 2025
    .obj file format is close to what you want. It supports vertex position in x,y,z coordinates, UV mapping and colour, anything above that is renderer specific.
    Asking for a universal scene exporter that includes universal shader support is like asking for a universal spoken language. ( does anyone actually speak Esperanto anymore ?? ).
    Post edited by background on
    A scene converter seems no more complex than what Microsoft and Google have done with PhoneLink were I can run over a million Android apps/phone/messages/pictures from within Windows.
    edited May 2025
    I remember complaining to Microsoft over 20 years ago that word processing is a human right, along with freedom of speech. (Open Office was at that time given converters to Word Documents, Word can now load and edit PDF's and I believe Adobe Acrobat can now load Word documents.)
    I also complained that operating systems should not be device dependent. A phone device should be able to adopt (communicate with) a different OS on-the-fly... (still waiting on that one)
    Currently there is antitrust litigation with Apple aimed at democratizing phone operating systems.
    Consumers should not be subjected to proprietary forms of communication. (Just a thought or idea.)
    Music has VSTs, a plethora of apps and instruments that work across all digital audio workstations. (some of the VSTs that I own: Native Instruments Collector's Edition, Omnisphere, Nexus, Falcon Synth, Antares Products, Wave Audio, VPS Avenger, Scaler 2, East West Sounds, Reason (Which I do not own but has since become a DAW as well, and a multitude of others.) Most Daws export tracks as "stems"...
    It is helpful to consumers when content is placed in a universally available format. Universal formats have not hindered content creation. And indeed, graphics cards should also play nice together.
    edited May 2025
    ...OK back to the RTX Pro 6000 for a moment.
    Here is a basic system specification built around the RTX Pro 6000. (A revision of the core specs I posted earlier)..
    GPU: Nvidia RTX Pro 6000 11,000 USD.
    CPU AMD EPYC 9135 16c/32t  base clock 3.65 GHz/boost 4.3 GHz TDP 200 W [Total memory support 9 TB DDR5]:  1,388 USD  .
    CPU Cooler Noctua NH-U14S TR5-SP6  220 USD
    MB: Gigabyte MZ33-AR1 Rev. 3.x Server Motherboard  [single socket] 759 USD
    Memory Micron DDR5 4800 288 GB ECC memory (6 x 48 GB)on 1,436 USD (this leaves 6 of the 12 DIMM slots empty).
    PSU: EVGA  Supernova  1200 P2 80+ Platinum  1200 W/  300 USD
    This is actually a fairly basic core specification to support the RTX Pro 6000.
    Case, drives, displays, keyboard, pointing device etc. not included for this discussion
    I primarily drafted this up to illustrate that workstation/sever grade components (particularly CPUs  and motherboards) are necessary to handle the Pro 6000's 96 GB of VRAM as it would require 288 GB of system memory (using the 3x VRAM formula) to support rendering. Ideally one would want some overhead so  384 GB (12 x 32 GB) would be more desirable (add 449 USD to substitute a Nemix DDR5 4800 memory kit).
    For all of the above (again not counting drives, full tower case, and peripherals) 15,083 USD (15,532 USD with 384 GB memory).
    So compared to a dual Epyc 9965 system, about two thirds the cost (projected) though still a pricey endeavour.(and that dual 9965 system would still need a GPU to support the display(s).
  • JPJP Posts: 97
    edited June 2025
    RexRed said:
    Daz Jack Tomalin said:
    RexRed said:
    Is anyone sorry they bought the RTX 5090? I'm glad I waited...
    Why would anyone be sorry? I dont think theres many with that sort of money to spend on a GPU... the 5090's are probably out a lot of peoples budgets as it is.
    I would spend $11,000 on a graphics card for Daz with 96GB of ram.
    I know people who are planning on buying 2x5090s for their system, well, that is nearly $6,000
    And then, what about AI using the graphics card to take your Daz items and turning them into animations and detailed scenes? This is just around the corner.
    This is where having multiple Nvidia Pro 6000s in a system would be needed. And what about the billions Hollywood currently spends on 3D hardware? They would certainly utilize this technology to its fullest for the entertainment value.
    This all utilizes Nvlink which means the pooling of cuda cores over multiple cards.
    I think these are overpriced but, 3 of them is about the price of a new car. Is that too much to spend on a robust 3D business?
    Daz should be able to employ this kind of hardware to futureproof their market share, including state-of-the-art ray tracing capabilities.
    Exporting Daz items to Omnisphere is a real pain when they can simply remain in Daz Studio… Otherwise, Daz and Omnisphere need true compatibility.
    If Nvidia wants to sell these cards to 3D artists they need "a lot" more photo realistic content than they have…
    It's available for $8,998 on Amazon.
    https://www.amazon.com/Blackwell-Professional-Workstation-Simulation-Engineering/dp/B0F7Y644FQ
    Looks like it has the same single 12V power connector. A shame for such an expensive and otherwise great card! If you need it for work it would make sense, and it can also be deducted as a business expense.
    Post edited by JP on
