dforce issue with last 2 daz versions
khryss666khryss666 Posts: 42
so this only seems to happen with biscuits kit hair and jam hair
ive zeroed and recompiled dforce kernals
ive tried with gen 8 and 9
happened in 4.23 and now also in 4.24
ive tried to zero everything i can find before simulation .. it used to work fine but now always looks like its blowing left
any help is appreciated
thanks
Post edited by khryss666 on
  • SquishySquishy Posts: 707
    When you say "it used to work fine" are you working with a copy of the hair you saved, or a premade scene/scene subset? do you have the character parented to anything? What happens if you use a completely blank figure (try one of the Dev Load figures)?
  • khryss666khryss666 Posts: 42
    edited May 2
    squishy thanks for the reply! ... i have tried to load fresh onto a completley blank figure (even after a fresh install of daz) also tried from saved scene
    (its probly something simple that when it gets figured out ill feel dumb)
    1920 x 991 - 636K
    Would you show a pic of this problem with your timeline showing please?
  • HavosHavos Posts: 5,587
    edited May 2
    I do not have Kit Hair, but I do have Biscuits Jam Hair, and when I tried it in 4.23 I am not seeing the same as you, the hair simulates as expected. See Image
    You could try going into the surfaces tab and reducing the collision offset. I have seen dForced items fly around when the Collision offset is too high.
    1024 x 1024 - 509K
    Post edited by Havos on
    edited May 8
    thank you havos ..
    squishy .. this time it didnt happen !!!! but i dont think just opening the timeline did anything to it??
    edit ... and i also tried it with a scene that i had with the messed up simulation already simulated .. and it also came out perfect when re simulated!!!
    edit ... tried it with a new figure .. and back to the side swept and all trys do that ... why did it work 2x correctly??
    1920 x 991 - 529K
    Iunno ¯\_(ツ)_/¯
    i think i figured out a work around ... if i just simulate , instead of simulate selected (ive always used simulate selected as its way faster) i dont have the issue
    I have also had issues with Simulate Selected as well, but I prefer it when working in a larger scene where you only want to simulate against a few objects.
    I did discover that Simulated Selected does work (at least for me) when you select the static objects first, and the dynamic ones last.
    edited May 10
    I have literally never used Simulate Selected (it never ocurred to me it might be faster) so I guess I've never encountered this problem before ¯\_(ツ)_/¯
    I've always used "freeze simulation" on individual objects when I don't want to sim everything at once.
    Post edited by Squishy on
