DAZ keeps crashing and asking to update NVIDIA driver
AinTunezAinTunez Posts: 38
Seemingly at random, when starting a render with Iray, DAZ will crash. The logs show the error below. My NVIDIA driver is 576.02, so the error makes no sense...is this version of DAZ unstable? What can I do to keep these crashes from happening, or to diagnose the issue?
2025-05-05 15:35:09.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
2025-05-05 15:35:09.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2025-05-05 15:35:09.581 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
2025-05-05 15:35:09.581 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(373): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Cannot render: found no usable devices. Please update your NVIDIA driver (www.nvidia.com) to at least 537.13, or enable CPU rendering.
2025-05-05 15:35:09.581 [ERROR] Iray :: Invalid parameters (NULL pointer).
2025-05-05 15:35:09.604 [INFO] :: Saved image: C:\Users\Ain3D\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2025-05-05 15:35:09.604 [INFO] :: Finished rendering.
2025-05-05 15:35:09.644 [INFO] :: Total Rendering Time: 1.90 seconds
2025-05-05 15:35:17.579 [INFO] :: Closing main window...
2025-05-05 15:35:17.579 [INFO] :: Saving Layout: C:/Users/Ain3D/AppData/Roaming/DAZ 3D/Studio4/layout.dsx
2025-05-05 15:35:17.582 [INFO] :: Clearing the scene...
2025-05-05 15:35:18.031 [INFO] :: *** Scene Cleared ***
...etc
2025-05-05 15:35:28.850 --------------- Daz Studio 4.24.0.3 exited ------------------
My specs are:
32GB RAM
NVIDIA GeForce RTX 5080 Laptop GPU, NVIDIA compatible
Intel(R) Core(TM) Ultra 9 275HX, 2700 Mhz, 24 Core(s), 24 Logical Processor(s)
Post edited by AinTunez on
  • barbultbarbult Posts: 26,387
    Daz Studio 4.24.0.3 does NOT support the NVIDIA 5000 series graphics cards. You need to install Daz Studio 2025.Alpha with DIM to get support for those cards. The Alpha is very limited at this point. Don't count on any of your purchased plugins or scripts to work in it.  The Daz Studio 4.X releases will NEVER support the NVIDIA 5000 series, we have been told.
  • Richard HaseltineRichard Haseltine Posts: 108,657
    Daz Studio didn't crash according to the log entries in your screen shot. If it does crash then that is something other than the compatibility with 50x0 cards (they simply won't work).
  • Thank you!
    The new Alpha did finally work with my 5000 series card.
    I especially upgraded for Daz (and okay, Blender and DaVinci Resolve).
