Appear On Table
I have a scene where I want a vase to appear on the table. Example: From frame 1 to 10 there is nothing on the table then on frame 11 a vase is on the table.
Is there a way to do this?
You can use Parameters > Display > Rendering > Visible in Render.
Since the Visible in Render property is Animatable, you can achieve your desired result by turning Visible in Render Off at frame 0 and On at frame 11.
You can display the Visible in Render property in the Timeline Pane by checking Other in the Types section of the Timeline Pane.
Great ! Thanks for your help !!
