Appear On Table
I have a scene where I want a vase to appear on the table. Example: From frame 1 to 10 there is nothing on the table then on frame 11 a vase is on the table.
Is there a way to do this?
  • CES3DCES3D Posts: 258
    You can use Parameters > Display > Rendering > Visible in Render.
    Since the Visible in Render property is Animatable, you can achieve your desired result by turning Visible in Render Off at frame 0 and On at frame 11.
    You can display the Visible in Render property in the Timeline Pane by checking Other in the Types section of the Timeline Pane.
    1663 x 1297 - 281K
    1663 x 1297 - 327K
  • Great ! Thanks for your help !!
