Is there a way to export a complete list of a Excel/text file, etc of all the Daz assets I own?
Moogee
Is there a way to export a complete list of my installed and/or available Daz 3D assets into a text file, spreadsheet, or CSV from either Daz Install Manager or Daz Studio? I want to catalog everything for project planning purposes."
Post edited by Moogee on
https://www.navicat.com/en/download/navicat-for-postgresql or https://www.navicat.com/en/download/navicat-premium
Trial version will do. Configure a Connection firstly, then export table: product.
You can export .csv format directly from DIM. In each tab (Ready to Download, Ready to Install and Installed) select all Products, then right-click anywhere on a Product and select "Export Selected to CSV". Choose which fields you want to use and Accept. Import the three files into your spreadsheet. Combine them into one sheet and sort as you like.
Thanks guys.
There is also http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products/start
I create VBA code in excel and do it manually. DIM CVS is very useful, and I have used it for years, but it is not absolutely accurate and has limited data columns. Also, anything you buy or own that DIM does not download, or that requires manual installation, is impossible to filter in either the product library or DIM. Those things slip thru the cracks and remain anonymous unless you step up to the plate and create a unique DAM system of your own.
