How to move object imported axis to a right place?
After import an object I want to scale it but the axis are displaced far of the object. How to center axis (X,Y,Z) to the object ?
  • GordigGordig Posts: 10,670
    It's best practice to import objects at world zero. Other programs have the ability to edit the axis of objects, but I don't know if DS does.
  • SquishySquishy Posts: 719
    Tutorial on adjusting pivot point/object center inside of D|S
  • D. ArnaezD. Arnaez Posts: 60
    Genius!!! Thank you Squishy!! Is exactly what I was looking for.
    yes
    edited April 2025
    Ok the video tutorial was great but, for some reason.. everytime I try to move the green pivots an any axis, the object is moved too. With the red pivot I have no problem. If I move it the object keep the position but the one the matter is the green pivot.
    Another issue... In this other project I created a plane that I want the hand be holding it. I tried to move the pivot and first problem. The axis are soo small. Is there a way to enlarge it? and again... I tryed to move the apivot position but the plane is also moving! What I'm doing wrong?
    1556 x 997 - 211K
    Post edited by D. Arnaez on
  • felisfelis Posts: 6,121
    I am not aware of scaling the arrows, but if you zoom in it will get relative bigger.
    Have you tried doing it in texture shaded view? - would expect better response on movements.
    Regarding movement of the object by moving these arrows. No idea, never seen it, and can't imagine how it could happen.
    Yeah I don't know what to tell you about the problem with moving the object center / pivot point, I can't reproduce that behavior. Works OK for me.
    Problem solved: I notice that there is no problem when the axis are ... lets say... not super small. I tryed with another ojbject and it works. Thanks to all of you!
    yes
