What i can do with white noise ?
nimonsi_5039111nimonsi_5039111 Posts: 65
edited April 2025 in New Users
Hello, how i can reduce white noise on the window, im using HDRI sky and  Dome & Scene enviroment mode
Thank you!
here's my settings:
Post edited by nimonsi_5039111 on
  • GordigGordig Posts: 10,819
    You've got it set to infinite max samples and infinite max time, but you've left rendering quality settings at default. You can try increasing render quality and/or rendering converged ratio, or just disabling render quality. I can't speak to which one will provide the best results, but those would be the first things to change.
  • nimonsi_5039111nimonsi_5039111 Posts: 65
    edited April 2025
    I tried setting the Rendering Quality to 3 and the Render Converged Ratio to 98%, but the difference was barely noticeable. I stopped rendering after 50 minutes—I could leave it running overnight, but I doubt it’ll make any visible difference. (RTX 3080 10Gb)
    920 x 760 - 94K
  • FishtalesFishtales Posts: 6,236
    Try dropping the Glossy values on the frame and glass.
    I tried reducing the Glossy Layered Weight (default was 1.00; I set it to 0). It helped a lot with other surfaces, but on the window, it did nothing.
    Glossy Reflectivity and Glossy Roughness also had no effect—I tried adjusting them from 1.00 to 0 and back, but nothing changed.
    Is it the clear thin glass shader which is the one to use for window glass?
    I'm sorry, I don't understand which parameter I need to change?
    226 x 716 - 36K
    230 x 720 - 33K
    225 x 673 - 29K
  • oh, i just returned to default all  settings and it's ok now,
    Thank you!
