2025 Alpha
2»
  • Alex@DBGAlex@DBG Posts: 61
    Gordig said:
    Ghosty12 said:
    stripe6499_9253833ae8 said:
    This question is kinda moot as I can't find it to download either, but when (if) I can download it, will it overwrite Daz 4.23 or create it's own directories and folders?
    If it is anything like past beta builds it will more than likely be a separate install.
    We can reasonably expect even the general release of 2025 to be separate from 4.X.
    We can also, reasonably expect, that when you announce something like this, the download actually works, but here we go ...
  • frank0314frank0314 Posts: 14,786
    edited April 2025
    richardandtracy said:
    Is there a way to get a manual download and manual install?
    I try to keep multiple versions of DS for testing purposes and find the only way is to do a manual install, and DIM is something I try to keep well away from due to the number of freebies I use/create and my wish to maintain my own library organisation.
    Regards,
    Richard
    No there isn't. It's only available through DIM like all the Betas
    Post edited by frank0314 on
    Regards,
    Richard
    Thanks. I'll wait until it develops into a manually downloadable package then.
    Regards,
    Richard
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,598
    not sure if any advantages I need on an older card, so will wait and see what others have to say
    could be interesting to see how it behaves on my older Win7 rig without a GPU ithough
    that PC has a lot of other issues though
  • CES3DCES3D Posts: 230
    Regards,
    Richard
    Regards,
    Richard
    In the 'Ready to Install' tab of DIM, if you uncheck 'Delete Package Once Installed', the installer will remain in the folder set as 'Package Archive'.
    955 x 787 - 243K
  • Exactly the same here, but Daz Studio 2025 is nowhere to be found...
  • brainmuffinbrainmuffin Posts: 1,282
    Glad to see I'm not alone. Look forward to trying it when it's finally available.
    From the announcement page:
    Note: The Studio 2025 Alpha Release is only available through Install Manager, consists of its own unique set of SKUs, and does not affect the 4.x release channels
    dbmelvin1993 Have you tried checking "Display Hidden" if it's there, then something isn't set up properly in your settings.
    I have tried everything already, including "Display Hidden", there is no Daz Studio 2025 in the list.
  • drucdruc Posts: 488
    My only question that hasn't been asked is will the public release of 2025 be a paid for program, going on the completely different naming convention?
  • Check it again. I see it now in DIM.
  • dbmelvin1993 said:
    I have tried everything already, including "Display Hidden", there is no Daz Studio 2025 in the list. Tried again, and now it showed up.
  • Richard HaseltineRichard Haseltine Posts: 109,523
    Closing this. It was not on the servers, PAs did have their own version which is why they saw it.
