Import material Daz to blender
2»
  • chrisvnchrisvn Posts: 85
    crosswind said:
    You bought the product from Renderosity.com ...  The vendors there usually have to split the product into multiple ZIP packages, like the one in your ss4, from 01 to 06. You need to put those six ZIP files into a folder, and unzip all of them. Then you'll got the sub-folders: data, People, Runtime.
    Then copy them into the root directory of your Daz Library !
    I looked at the installation note and on the manual the instructions were to unzip the folders directly into the Library, so I did that, I was able to use the cropped hoodies except one where I don't see the US colors and there are edges that interact with the character's skin and also when you move it the hoodie goes through the skin (screen_V1), I think it's more a settings thing, but I'm new to this is there a tutorial for that?
    I noticed that to change the hoodie material at first it didn't work, then clicking on the eye deactivated it then reactivating it by clicking on the hoodie for example I changed it and it's the same for the rest this is correct way (screen_V2) ?
    1856 x 996 - 306K
    1900 x 1056 - 344K
  • crosswindcrosswind Posts: 9,620
    edited April 2025
    You either can unzip the package file one by one or holistically unzip them into a temp folder and copy them to the library all together. I always install 3rd-party product with Content Wizard, so I always make a one package without any garbage folders / files (e.g. Documents... etc.)
    Short Hoodie 10 material preset is with "US textures"... though I never use it ~~ devil
    The issue you had is because of the character's shape is Sakura 8 but the vendor didn't give a FULL HEAD MORPH for it on the hoodie. You can follow this tutorial to fix the FHM... https://youtu.be/HLt0jpxQA20?si=UeJ67vXsv0k2HCg1
    The tutorial from Mada is for fixing FULL BODY MORPH (FBM) but you can follow it similarly to fix FHM for the hoodie. I fixed it by using Blender. (ss1) If you don't know Blender or ZBrush but have Mesh Grabber, you also can fix it...
    The material presets work for me. I couldn't reproduce any issue with them. Maybe it was a glitch on your side....
    2560 x 1392 - 2M
    Post edited by crosswind on
    edited April 2025
    Yes, in the end, so since I unzipped it, it went well, I unzipped it directly into the library the necessary files...
    But I have the colors with the same hoodie selection as you, however in fit to I don't have sakura 8 but genesis 8 and yet I have the same selection as you! I don't understand because we have to put the genesis 8 female body first..(screen V1 et V2 )
    Regarding the video link, it's too advanced for me, I don't even know how to go into editor mode!!! If it worked for you, it will work for me too!
    And for the clothes that pass through the body when the character moves, do you think it is necessary to save the body in collisions? I have not tried in blender, I will have to try
    1879 x 1024 - 265K
    1847 x 1002 - 291K
    Hello, maybe you didn't get my post? I'll resend it to you. Thanks.
    1879 x 1024 - 168K
    1847 x 1002 - 183K
