Import material Daz to blender
One thing I still don't understand with my renderhub character, I can't import the character with her cyborg body into blender, she arrives with the genesis 8 body.
I have to apply the genesis 8 body and then apply the cyborg body, otherwise it doesn't work !
but I can't import it why ?  Thank you for your help again
«1
  • crosswindcrosswind Posts: 10,356
    I don't quite understand, what do you mean "have to apply the genesis 8 body and then apply the cyborg body" ?
    -First in Daz I put the genesis8 body, then I 2 i go to Marcus and apply the head and in 3 the cyborg body in the materials, then I save my character in files; save as scene
    then go to script and export to blender
    -in blender I open daz setup / easy Import / on the right in the window I select in the folder where the character is saved the file dbz / in the presets; genesis 8 / I check in the list: Body and I click on Easy Import Daz at the bottom
    and i have only the Body
    1570 x 1015 - 213K
    1766 x 1040 - 268K
    That seems to me just the material on figure's body, so you couldn't see the material in Blender after importing with Diffeomorphic ?
  • lilweeplilweep Posts: 2,883
    You didnt say what bridge from daz to blender you are using, but it is apparent that you are using Diffeomorphic.
    You didnt say what product you are using but it is apparent you are using "Syph and Bodysuit For Genesis 8 Female"
    You didnt say if the bodysuit is a geoshell, but based on the product (which i had to google) i can see that it is a geoshell
    Information about diffeomorphic geoshells can be found here: https://diffeomorphic.blogspot.com/search?q=geoshell&max-results=20&by-date=true
    Yes is allright I can't see the material
  • chrisvnchrisvn Posts: 89
    edited February 2025
    I had to say all that too yes indeed everything you said is correct! sorry I really need to be more precise ...I try also with the bridge Daz to blender is same of Diffeomorphic I can't see the body ! I will read the link you give to me
    Thank you at everyone for your help
    Firstly, check if the "body suit material" is a Layered Image on figure's Body surface in DS... like a tattoo. If so, you won't see Layered Images in Blender in Solid Mode even with show texture option, you need to view it in Material Preview or Render Preview mode.
    2169 x 1342 - 2M
    Post edited by crosswind on
    the problem is that i can't see where to look because i haven't seen the body cyborg in any form! and also i haven't: archipack material library
    1892 x 1040 - 271K
    383 x 877 - 67K
    I noticed that products that are not from Daz like Renderhub and Roderosity worked with difficulty or not at all because I have no trouble importing Daz characters with their clothes. But usually is shutbe working but is really difficult to instal ! i mean for me !! is beacause i didon't understand how is working i try to understand ...
    No need to compare the UI from my screenshots because I have quite a few add-ons installed that bring different settings in property panes...
    Finally, I found the product that used to be sold in this store :  http://docs.daz3d.com/doku.php/public/read_me/index/59875/start ; If it's the product that you're using ~~ in which the bodysuit is a geo-shell.
    As default, Diffeo just imports shell as a material. As I said above, you need to switch to material preview mode or directly go to Shading workspace ~~ I don't have that product but used another geo-shell product as an example. (ss 1 ~ 2)
    If you need to have a goe-shell node in Blender, go to Global Settings in Diffeomorphic, set Shell method to Geometry Node... (ss 3) Then you'll have a shell node after importing the scene. (ss 4)
    2560 x 1392 - 1M
    2560 x 1392 - 2M
    2560 x 1392 - 883K
    2560 x 1392 - 2M
    Thanks,sorry I haven't had time to look yet, I'll come back and tell you during the week
    I think I did as you said, but it's not easy because the shell doesn't show! At one point I set metal to 1 and it started to display what you see on the arms but it's far from that and in the maps it's everywhere the same G8FbaseTorso, I don't know what you think! I also looked for how to activate a GeoShell on blender I found some interesting stuff but nothing to see!!! In case I'm ready to give you the mehs file with wetransfer
    1910 x 1064 - 235K
    1898 x 1050 - 196K
    1904 x 1048 - 229K
    1892 x 1040 - 271K
    Post edited by chrisvn on
    The converted shell seems having no correct settings with shader node in your screenshots.
    I tried with another shell clothing product: Easy Pants on G8F. Diffeomorphi converted correctly. What's the version of Diffeo you're using ? I tested with Diffeo version 4.4... but the older versions SHOULD also work IIRC.
    2560 x 1392 - 2M
    I don't know, I think it's the latest version because I'm using the latest version of blender, it's that in the preferences and extensions I don't see difféomorphic, and I remember when I installed it I had seen it! I admit it's too complicated at the beginner stage I'm at, I can't even see which node you're talking about, can I send you the file by wee-transfer? seeing what you'd have done, maybe I'd understand more!
    1917 x 1050 - 299K
    Yea, definitely the node for shell materials is missing. Can you check and post a screenshot of your scene in Daz Studio ? Expande the figure node to check if there's a geo-shell node for the bodysuit in Scene pane?
    Besides, press N in Blender to open N-Panel, check the version number of Diffeo.
  • I made you a screenshot on the right you see the scene pane and then there is at the bottom Syph mech Skin which is deactivated but that is the skin it is not the cyborg body,
    And what is Syph Genitalia?
    In blender I do not know if it is the version of difeo here, as I told you it is weird before I saw Diffeo in the preferences and extension now I do not see it anymore, moreover I do not have like everyone else a Diffeo tab when I click on N !!
    PS; do you see verywell my screenshot ?? because I download my screenshot from the website and is completly blur
    1912 x 1072 - 289K
    1910 x 983 - 225K
    The screenshots and the version seem both fine to me...
    I have to ask: how many Daz Libraries do you have ? Have you correctly configured the path of the Libraries in Global Settings of Diffeo? especially the library path in which you installed this Syph product ? (check ss1)
    If the path is not correctly configured, the shell UV and textures cannot be imported so you have no way to find the shell work ~~
    Edit: As for the Diffeomorphic panel you ever saw, we just use SIMPLE TABS add-on to merge the Diffeo Setup and Runtime panels together (check ss2). You can download the free add-on in here: https://blendermarket.com/products/simple-tabs?search_id=37548803
    2560 x 1392 - 576K
    1287 x 1178 - 337K
    crosswind a dit :
    Les captures d'écran et la version me semblent toutes les deux correctes...
    Je dois demander : combien de bibliothèques Daz avez-vous ? Avez-vous correctement configuré le chemin des bibliothèques dans les paramètres globaux de Diffeo ? en particulier le chemin de la bibliothèque dans laquelle vous avez installé ce produit Syph ? (vérifiez ss1)
    Si le chemin n'est pas correctement configuré, les UV et les textures du shell ne peuvent pas être importés, vous n'avez donc aucun moyen de trouver le travail du shell ~~
    Edit : En ce qui concerne le panneau Diffeomorphic que vous avez déjà vu, nous utilisons simplement le module complémentaire SIMPLE TABS pour fusionner les panneaux Diffeo Setup et Runtime (vérifiez ss2). Vous pouvez télécharger le module complémentaire gratuit ici : https://blendermarket.com/products/simple-tabs?search_id=37548803
    Ha I didn't think about that at all because I saw the daz library as you can see (V1) actually I have another library (V2) so I should put Syph in my DAz 3D library?
    I created a folder in La Library, and tried it, but it still didn't work! (Syph_V3) and (daz_Syph_V4) (ShaderEdit_V5) it's crazy!
    In the global parameters I've got a File error and the setting directory is still C:/User....  While everything is in the D, you can see on the photo that the path is D:/Daz 3D Dossier....( V6)
    -Thank for the link SimpleTabs
    1854 x 992 - 289K
    653 x 492 - 31K
    1869 x 960 - 262K
    1880 x 1008 - 194K
    1896 x 1014 - 325K
    1466 x 854 - 193K
    edited March 2025
    No... you wrongly extracted the product content...You don't need to create new folder or something... You should :
    1) Press F2 in DS > Content tab > Content Directory Manager, under Daz Studio Formats, only keep the path: D:/Daz 3D Dossier/Utilisateurs/Public/Documents/My Daz 3D Library. Delete other paths !! Accept.
    2) Press F2 again > General tab, Clear DSON Cache Files ! Accept.
    3) Extract the content folders of this Syph product to D:/Daz 3D Dossier/Utilisateurs/Public/Documents/My Daz 3D Library  Be Noted: you must directly extract: data, People, Runtime folders to the Library, not any sub-folder in the root directory within in the ZIP package !!!
    4) In a New Scene, load G8F, load Mech Skin (bodysuit) from the above extracted content folder to G8F. Save the scene and Export to Blender. Import to Blender with Diffeomorphic.
    As long as you configure / do each step correctly, it'll work ~~~
    2560 x 1392 - 1M
    Hello sorry i will comming back next weekend because i have for nesxt Friday à évalution to give
    Hello how are you?
     so you mean that I have to install the Syph and bodysuit folder in the My daz library folder and I just take the data, poeple, runtime folders?
    I did this at the beginning and it didn't work!!! I had trouble with this folder and not only with this one note it's not easy to get mesh from elsewhere than daz 3D
    I didn't press F2 to clear the cache, you've just taught me that! but I'm going to try again! so I'll just take the data, poeple and runtime folders? That's all there is, but they're in a folder called content
    Hello how are you?
    Yes, you must just extract the folders of : data, People, runtime... to your Daz Library, check the below screenshots.
    I know lots of vendors on Renderhub ZIP the product package with many folder levels... that misleads lots of DS users ~~
    1902 x 985 - 994K
    501 x 1294 - 118K
    1158 x 747 - 38K
    Hey
    we'd say it was the folder arrangement, yes it's really a problem these files there I'm one or it's the same, I have folders subfolders with other subfolders that contain themselves subfolders something crazy, so I do not know where to extract all that but I'll try to do the same ! thank you really for your patience, maybe I'll show you this folder with lots of subfolders if I can't and I'm sure I'll understand later because it contains a lot of sub-folders.
    1911 x 1067 - 255K
    NP~ It seems that you've already got the job done yes
    So no is does work !!!
    In the folder there are too many subfolders ;
    -in Data there's sparkman/dforce g8 style suit / G8 short hoodie and G8 sport pant
    -in Documentation there's just documentation, nothing more
    -in People there's ; genesis 8 female / clothing/ sparkman / dforce g8 sport.../ and material and a pose folder with other files
    -in runtime there's texture / sparkman / g8 sports st..... and all the textures inside
    by law there's a problem with this folder it contains too many useless subfolders and I have no idea how to do it, tomorow night i will try to create a new folder and drag inside juste one folder of each sub-folder
    1005 x 332 - 29K
     I tried the same way, but it doesn't work. As I said above, there are lots of subfolders, so it's really hard to understand ! I you doing with that ?
    Thank
    It worked well on my side. There're only 3 sub folders ( data, People, Runtime ) in the ZIP file that you need to extract.... as I showed in the above screenshot.
    Yes is wath I doing, the thing is, I don't know what to do with all these folders (screen_V4) (they should really have an installation guide!!), I copied and pasted Poeple and date and all the runtimes from the other folders into G8 (Screen_V5) but I knew that it wasn't going to work because they were outside the library (screen_V1). I tried again in the library (Screen_V2) and a second time by deleting useless subfolders it put exclamation marks everywhere (Screen_V3)
    1856 x 1014 - 288K
    864 x 935 - 123K
    747 x 947 - 115K
    1675 x 862 - 150K
    1505 x 1019 - 65K
    You bought the product from Renderosity.com ...  The vendors there usually have to split the product into multiple ZIP packages, like the one in your ss4, from 01 to 06. You need to put those six ZIP files into a folder, and unzip all of them. Then you'll got the sub-folders: data, People, Runtime.
    Then copy them into the root directory of your Daz Library !
    crosswind a dit :
    Vous avez acheté le produit sur Renderosity.com… Les vendeurs doivent généralement le diviser en plusieurs fichiers ZIP, comme celui de votre SS4, de 01 à 06. Vous devez placer ces six fichiers ZIP dans un dossier et les décompresser tous. Vous obtiendrez alors les sous-dossiers : données, personnes et exécution.
    Copiez-les ensuite dans le répertoire racine de votre bibliothèque Daz !
      When I select the 7 folders I have runtime and document there's a problem with this file I'm fed up with it with Renderosity I do it with but of course not workink
