How to use use hair across Genesis's?
Drogo Nazhur
I know how to use clothing across different Genesis's but how do I do that with hair without increasing the size of the saved scene file? Thank you in advance.
The scene file gets bigger because when you convert the item to a new figure it has to create new asset data - with the original your scenes are just linking to the asset files, but with the converted data they are embedding it in the scene file. The total amount of data stored doesn't chnage, but if you use a converted item in more than one scene it may be worth usign File>Save As>Support Assets>Figure/Prop Asset to create asset files that the scene can link to (and then load that, instead of loading the orignal and converting it, next time you want to use that hair - otherwise you don't gain anything).
Load the hair without fitting, and use the translate and/or scale dials to position it correctly and then parent it to the figures head. Caveat: this likely will not work with dforce hairs.
I'm getting the following error ...
2025-04-04 23:09:26.972 [INFO] :: Saved image: E:\DAZ\Public Documents\My DAZ 3D Library\People\Genesis 8 Male\Hair\toyen9blonde.tip.png<br /> 2025-04-04 23:09:26.984 [WARNING] :: ..\..\..\..\..\src\dzpostgresqlobjectdatabase.cpp(37): db insert error: ERROR: invalid page in block 4284 of relation base/16384/16873DO not overwrite the original user-facing file when saving a figure asset... better save the figure asset as a new DUF file in another Daz Library.
