Is it possible for filed content to go mia
Hi:
I have a question. Is it possible for product that have been categorized to be suddenly missing from categories?
I've begun to notice content isn't filed properly, although I am pretty sure I filed the stuff away... IE Created a product, and put it in a product folder.
Today, I went through one of my locations folder and found several items simply not in that folder. And I know I categorized them.
Could this be indicative of a database issue?
    That sounds like a database issue, are you using Valentina or PostgreSQL?
  • Just using the latest version of DAZ studio. Don't know which it has. But its begun happening more...
    I would Export User Data if you haven't done it recently, reset the database, install PostgreSQL CMS, and re-import metadata.
    edited September 2015
    Thanks. That's good advice. I'll do that now.
  • Yes. I've had that happen a couple or few times. Once  I had to follow all the procedures above since I needed to switch from Valentina de Posgre. Another time reimporting metadata was sufficient, as that was the only issue. Worked like a charm.
