Iray and Supersuit for Genesis
I'm having an issue rendering this in IRay. No matter what I try the texture comes out flat. I can render the same image in 3dL or Reality and you can see the details. I've tried it with and without applying the IRay base shaders but the results are the same.
Any clues would be appreciated
A couple of examples: First the IRay version, then the same image and lighting in 3DL
