Iray and Supersuit for Genesis
Sisca
I'm having an issue rendering this in IRay. No matter what I try the texture comes out flat. I can render the same image in 3dL or Reality and you can see the details. I've tried it with and without applying the IRay base shaders but the results are the same.
Any clues would be appreciated
A couple of examples: First the IRay version, then the same image and lighting in 3DL
1000 x 1300 - 1M
1000 x 1300 - 1M
The bump or normal map is not being applied properly. You will have to look in the settings. If you convert to the Iray default shader hold down the control key when clicking it and chose the option which lets you keep the maps. It is definetly in the materials setting somewhere.
Iray doesn't handle displacement the same way 3Delight does, the surface needs to be highly subdivided for displacement to work in Iray.
Iray and displacement http://www.daz3d.com/forums/discussion/57100/iray-displacement
