Smoothing Belly
I'm creating a character (G9) but I want him to be a "regular joe", however the base I have has his belly a bit too toned. I tried to find something I could use to revert that but I can't. The problem is the vertical crease in the middle of the abs. I have Shape Shift and I can only add definition, not remove. I can also make the belly bigger but that doesn't remove the vertical crease. What can I do? Is there any product or any other way to smooth that area?
I don't think there would be a simple solution since the definition is probably being supplied by a custom-sculpted figure morph. If the figure has a split head and body morph (as many figures do) you can dial the body down to zero and perhaps recreate the parts you did want from other morphs? If you still wanted the rest of the body morph then there is the Shape Splitter product in the store but I don't have experience with that so not sure how easy that is or whether it will do what you want.
Easy Shape Master and Vinme Morphs for Genesis 9 both have morphs for Belly Smoothing (ss1). But if you know Blender, you can quickly smooth the belly (by using smooth brush and import as a morph to G9) for free ~~ (ss2)
