Star Trek Builders Thread!
1293032343551
  • mdbruffymdbruffy Posts: 2,345
    MotoTsume said:
    one more time with TMP corridor
    Fantastic! I've saved all 3 verisons!
  • TimbalesTimbales Posts: 2,425
    thanks for the ready room, Rduda!
    800 x 640 - 230K
    edited September 2012
    Okay, there are 4 picture tubes in this first release. Created in PSPX4 from little pictures.
    http://www.sharecg.com/v/64541/view/15/2D-Resources/ST_Badges-01_nc_PictureTubes
    Intended for use in texturing clothing etc for the models.
    799 x 799 - 87K
    600 x 600 - 131K
    Post edited by patience55 on
  • MattymanxMattymanx Posts: 6,998
    Well I took a look at the Voyager Bridge again and wow, what a mess I somehow created. So I am in the process of fixing the rigging and the floor light. When its done, poser users will have a mat file that will set normals forward for rendering. All mesh lights apprear ok so far so it should hopefully work well in LuxRender (which I will test)
    Other then that, the corridors are on hold while I poke at the bridge but they are in excellent condition and will soon go to DS for rigging.
    I have one other related interior I will convert prior to going back to the ships. All I will say is that it is related to the other two interiors I am working on. With this one interior, your only limitation is your imagination! ;P
    Oh boy!!!! ... patiently waiting ... yeah right ... oh boy!!!! :-)
  • GRFK DSGN UnlimitedGRFK DSGN Unlimited Posts: 1,123
    Another page posted for viewing at my blog.
    600 x 464 - 399K
    So close ... then Hexie had a tizzie fit ... so hopefully tomorrow I'll get this one finished on the other computer.
    Modeling in Hexagon is fun. Learn all kinds of things one never knew one should ever have to know lol ...
    I'm going to hazard a guess that one shouldn't apply smoothing on an object with shading domains hidden ... crashed it every time!
    425 x 443 - 57K
    Voyager
    New Voyager Bridge is up. I am hosting it right away on my Mediafire account UNTIL Trekmeshes gets the update. Once the update is back on Trekmeshes I will take it down from my Mediafire account. I just want people to have it right away.
    900 x 900 - 826K
    Post edited by Mattymanx on
    Mattymanx said:
    Voyager
    And the link to your Mediafile is where?
    mdbruffy said:
    Mattymanx said:
    Voyager
    Its in the Ships of the Line thread. Thats why I have that in my sig now, for easy access to the whole list. And why I post the updated date there too.
    Mattymanx said:
    mdbruffy said:
    Mattymanx said:
    Voyager
    Got it. Thank you.
    mdbruffy said:
    Mattymanx said:
    mdbruffy said:
    Mattymanx said:
    Voyager
    Got it. Thank you.
    Excellent! Your Welcome! :)
    Mattymanx said:
    Voyager
    Thank you! Downloading now.
    Mattymanx said:
    Voyager
    Your welcome. It is the same model you helped me with in the first time. I would have redon the whole thing but that would be too time consuming.
    i forgot to mention, there is a new map for the Plaque so it can be made to look a LOT better. Its the spec map.
    mdbruffy said:
    ... edit ...
    In the meantime, the kit is now available at my DA gallery:
    http://mdbruffy.deviantart.com/gallery/#/d5dh8it
    Thank you!
    This is an "as it loads" of the pz3 file in D/S3. Very nice :-)
    514 x 478 - 44K
    600 x 600 - 39K
    Mattymanx said:
    Mattymanx said:
    Voyager
    You're a brave man! I had that on my "to-try-again" list and just couldn't bring myself to try again. Apparently asking Hexagon to do certain tasks has rather disastrous results. One day when I have lots of time and hopefully enough experience I "might" tackle it again.
    Mattymanx said:
    Voyager
    it's gorgeous! awesome work!
    I have noticed recently that though certain things are easier to do in Hex as far as the UI is concerned, Carrara is far more hassel free doing the same thing even though its not as obvious as to how to do it.
    As for the Bridge, it would have been a fresh conversion from the MAX file with different export settings. Because of how much we had to do last time, it kinda stuck with me and I remembered where the major issues were. Aside from having to redo all the rigging, which for some odd reason got all screwy compared to how I thought it first got rigged, I only had to flip the floor light which was easily done by importing a new copy of the bridge and taking that piece out and merging it to the old. Thank God ai also remembered what to scale the bridge to last time too. So this time I scaled it on its way out of Carrara instead of trying to deal with it "full size" in DS when rigging.
    Thank you Tim! :)
  • edited September 2012
    Thank you Tim! :)
    I can confirm it renders nicely in Poser Pro 2012, too. It has the usual pre-render issues, but it doesn't harm the render in any shape or form.
    Post edited by prydonian_96d3f0dd8a on
    'for next time' ... seems to me somebody was wanting a pic of this item.
    363 x 610 - 34K
  • willdialwilldial Posts: 32
    The other day I purchased Starship Engineering Room 2 at Vanishing Point. I really liked the Enterprise-D Texture Add-On freebie for it.
    That reminded me that the first Starship Engineering Room looked like the Deep Space Nine's Defiant Main Engineering except for the textures. I looked to see if there was an Add-On for it. Sadly, I could not find one. Does anyone here know if there was a Defiant Add-On for first Starship Engineering Room?
    Thank you.
    Thank you!
    Thank you!
    You're welcome ;-)
    And now ... another table!
    A 'bar table' [bears some resemblance to one found in Quark's Bar DS9]
    Tweak as necessary for the light panels ... shaders seem to work well with almost any uvmap.
    Made the open grid [great place to pour unwanted drinks eh?!] with included textures.
    Might need to be tweaked in Poser for the proper effect.
    http://www.mediafire.com/?3x9k4bf7x1lv9eh
    or
    http://www.sharecg.com/v/64569/view/11/Poser/QBTable-nc
    497 x 600 - 41K
    697 x 726 - 53K
    600 x 484 - 29K
    600 x 600 - 79K
    600 x 600 - 47K
    Thank you!
    You're welcome ;-)
    or
    Question: Where does one put their feet when they're sitting at that table? There's no room under it.
    mdbruffy said:
    Thank you!
    You're welcome ;-)
    or
    I know! lol ... I've been watching DS9 and notice few shots that would illustrate that. I call the middle area a shelf figuring maybe some can sit comfy that way ... or stand?
    274 x 265 - 18K
    In case anyone has missed it, the Voyager Bridge is redone and available! Please see the link in my sig, its listed under sets
    The Corridor interior pieces are slowly under way getting rigged. All will be figures even though most should be props. I am doing this to ensure they rotate correctly in Poser. Again, the corridor set is a two in one. They are based on Intrepid and Sovereign class corridors.
    Mystery item... is a Holodeck, Voyager style. Its made by the same guy who made the Corridor set. I was able to match the scale to the corridor set almost 100%. You will be able to line it up with a couple of the corridor pieces manually. It also has a variation built in. Not sure what is meant by "T Class" in the set but the room comes with two exits and one of the two exits has 2 different doors too. Each is the floor and a wall with the opening doors. Since the standard room doors with the Corridor set were never designed to be opened, I seperated two sets of doors from the Holodeck so they can be used with other sets. The Holodeck is a good quality mesh. This will be rigged so that the whole mesh loads at once and you can shut off what you dont need. All normals have been corrected to my knowledge so the lights should work as mesh lights.
  • MotoTsumeMotoTsume Posts: 520
    can't wait :)
    Sounds rather interesting.
    The flag figure is done. Just working on some morphs for it ... I'm not an expert flag folder so don't expect too much there.
    Another WIP started today will hopefully be passable as a Klingon's Captain Chair ... minus the text because the text on the reference image isn't readable. It will also be a .cr2 file.
    In checking displays on various browsers; with IE9 on the Google page :-)
    696 x 447 - 223K
