Saving additional shape presets from 'memorised' shape?
I would like to save shape presets from a character and want to use 'check only modified'. I thought if I used 'memorise shape' beforehand, if I were to then make the nose bigger and save, and 'check only modified', it would just find the nose, but no. There's still a lot of 'ghost morphs' being selected, so I have to go in and uncheck a lot of stuff before saving.
I don't want to create morphs from the base model as it's harder to see the desired results.
Is there a way to bake, freeze or set the current model shape as default and then apply further morphs so that can be saved out easier?
Thank you!
  • crosswindcrosswind Posts: 10,304
    Memorize Figure Shape has nothing to do with "Check Modified"... as long as a morph property has a non-zero Value, it's Modified.
    As for your requirements, the better way is to create a full head morph and a full body morph for your character 1st of all. Then you can further fine tune the shape with PHMs and PBMs...
  • Kr00kedKr00ked Posts: 8
    PHMs and PBMs?
    Partial Head Morphs and Partial Body Morphs ~~
