Redownloading everything after switching PCs?
I've always had my DAZ content on an external storage device. And I've recently upgraded PCs. I set everything up to my new PC for my content, yet it isn't registering it. Do I have to redownload everything?
Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 109,616
    Are the files appearing in the Content Library pane, under Daz Studio Formats or Poser Formats (as appropriate)?
  • Write IdeaWrite Idea Posts: 466
    The ones I've redownloaded are, yes.
    My CMS Cluster is set to by default file in the C:\ drive. However, the DAZ Connect Data, DAZ Studio Format, and Poser Format are all set to the D:\ external hard drive.
    Should my CMS Cluster also be set to the D:\ eternal hard drive?
    Did you copy the old database across (with DS and DIM closed)? if so, point to the folder that holds the ContentCluster folder; otherwise it doesn't matter, but you will need to reimport metadata to use the database driven views. To reimport metadata, open the Content Library option menu (the lined/hmaburger button in the top corner)>ContentDB Maintenance, select Reimport Metadata, click Accept, then seelct all in the next dialogue.
  • ElorElor Posts: 3,641
    As long as they are on the same computer and DS knows where to look for it, they can be on different drive: on my Mac, the CMS database is stored on its internal SSD while everything else is stored on an external SSD.
