Window blinds that can be distorted and looked though?
Pitmatic
in The Commons
Hi
I want have say my private eye character peer through closed window blinds, with a gap made by bending one or two individual blind strips down so from outside you can see their eyes or part of the face though the gap formed.
Is there a blind in the store that can do that and can stand the closeup?
thanks
No ideaexisting product but can come up with an alternative solution if none exist.
You could techincally make yourself a Plane primitive with enough division to be morphable and duplicate it into an array to create a convincing blinds. Good shader will sort out close up.
That is a plan Tomhip. I shall have a go tonight, I have never tried morphing anything so will be a good learning experience.
Just to clarify as I missed that in original post I meant using Mesh Grabber to achieve that effect.
You have to remember that blinds are rather stiff, so it would bend all the way to the nearest point where it is kept in place
If a PA decides to make it they should call them peaky blinders.
