Knee bend causes deformation on morphed G8.1F thigh -- JCM problem?
Hi all, I have a heavily morphed G8.1F character whose left front thigh shows mesh distortion when I bend the left shin. See screencap. Is this a JCM problem? How can I go about troubleshooting and fixing? Thanks in advance.
--MW
  • crosswindcrosswind Posts: 9,822
    Probably... though I also think there might be other culprits. You can check Currently Used with Show Hidden Properties... turned on, see if any other pjcm... morphs unexpectedly dialed.
  • Crosswind -- thank you for your quick reply. I went into Parameters and found that Use Limits for the Flex Quad Left had been somehow unchecked, so I put Use Limits back on, and the problem was fixed!
    --MW
