• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
How can I import expressions?
yusmarytorrealba39yusmarytorrealba39 Posts: 0
February 25 in Blender Discussion
Hi, I'm having a problem when I want to use custom expressions in Blender.
I'm using Genesis Face Controls specifically the .duf expressions from the FACS + Phonemes folder and in Daz3D they work fine, however, I can't find a way to use those expressions in Blender.
I am using Diffeomorphic, and what I want is to convert these expressions to shapekeys format that I can use comfortably in my model.
Is this possible?
  • 442191327442191327 Posts: 2
    February 25
    Hi,
    Maybe you should import the custom expressions from DAZ Posing Panel(Right Side) by Diff Import Custom Morphs
    457 x 161 - 15K
    751 x 1018 - 285K
  • PadonePadone Posts: 4,020
    February 25
    Yes for custom expressions you can use custom morphs, that I suppose being your "phonemes" in this case. However be aware that FACS include visemes, so you usually don't need extra custom morphs for phonemes. As for converting to shapekeys there's a tool in the morphs panel.
    setup > morphs > shapekeys > convert morphs to shapekeys
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Morph Tools/Shapekeys
  • yusmarytorrealba39yusmarytorrealba39 Posts: 0
    February 25
    442191327 said:
    Hi,
    So how would I do it? I don't know how to add those .duf expressions so that they appear there in the pose menu as in the image you are showing me.
    Another thing is that the expressions only work if I apply them to the face rig, because if I double click on them with the character selected, it just doesn't do anything, so I have to join both (?
    1102 x 682 - 387K
  • crosswindcrosswind Posts: 9,592
    February 26 edited February 26
    yusmarytorrealba39 said:
    442191327 said:
    Hi,
    They're Pose Presets rather than Custom Morphs... and in DS, those GFC FACS Pose Presets only work on Genesis 8 Face Controls node rather than G8 figures per se.  But in Blender, you can directly select G8 armature to apply the pose presets ~~
    Edit: BTW, though they're named as "FACS", they have nothing to do with FACS on G8.1... but just push values to joint rotations on G8.x 's face rigs.
    2560 x 1392 - 979K
    2560 x 1392 - 1M
    Post edited by crosswind on February 26
    February 27
    442191327 said:
    Hi,
    1. You want to import the DAZ custom expression products into Blender (For Example: 100 must Have Expressions For Genesis 8 Female)
    2. Filter them on the Posing Panel(Right Side) by "i3d" what ever ( you must import them from Posing Panel)
    3. Click the Gear Icon and choose Parameter Settings
    4. Click the File Path Icon "..." and copy the File Path
    5. Select your Figures on Blender (For Example:Genesis 8.1 Female Mesh) and Click the Import Custom Morphs on DAZ Setup Panel
    6.  Paste your file  path on the Blender File View and Select all file for import, you also can change the name like 100 must Have Expressions
    7. You can find the Cutoms Expressions on DAZ Runtime --> Customs Morphs
    They are Morphs, work well without Face Controls
    781 x 1421 - 273K
    793 x 1101 - 199K
    949 x 900 - 181K
    1691 x 865 - 239K
    2057 x 1580 - 380K
    2045 x 1341 - 375K
    1546 x 1506 - 295K
    February 28
    442191327 said:
    Hi,
    Nothing works for me... my models are .duf (as I showed in one of the images above, they come directly from the addon folder), they don't even appear in the pose panel... they just apply directly to the face rig.
    Then if I do the Blender thing to import the dufs, it appears that it worked but they don't appear and don't do anything.
    372 x 563 - 24K
    560 x 639 - 119K
    February 28
    442191327 said:
    Hi,
    That's what I was doing and it would be importing one by one and then clicking on “Save as shape key”.... But they don't import well, the part of the eyebrows and the head works fine, however, for the mouth it doesn't work.
    Only the lips move, however, the jaw, the teeth and their position and rotation do not move when loading the poses.
    February 28 edited February 28
    You are using expressions which are poses for the face rig, the face rig then uses facs. In this case you have first to load facs for the face rig to work, then you can load the poses with: runtime > poses > import pose. Or convert the pose set to blender assets with: runtime > import asset.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Posing/Import Pose Library
    To convert to shapekeys in this case is more complicated because the pose affects bones and facs. So you have to do it manually with the blender tools: shapekeys > join as shapes, over a duplicate figure without facs.
    p.s. To convert to shapekeys is much easier to use the standard facs, rather than facs poses for the face rig.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Morph Tools/Shapekeys/Convert Morphs To Shapekeys
    Post edited by Padone on February 28
    February 28
    442191327 said:
    Hi,
    Again, the product https://www.daz3d.com/genesis-3--8-face-controls that you're using utilises Face Control figure to just call the joint rotations on G8 figures (under face rigs), by using joints + Pose Controls with its ERC Freezed Sub-Components (screenshot 1).  You're right, I tested more Presets and found some of the presets don't work as you don't have those Pose Controls in Blender... i.e. Diffeo cannot support this Face Control to fully work.
    After revisiting your requirements, you should avoid using this product... instead, directly use FACS, i.e. check FACS option when importing Daz scene. FACS will be auto-converted to shape keys. (screenshot 2)
    If you DO want to import those Pose Preset from the above product, the only practical way is to create custom morph for them one by one and then import into Blender ( screenshot 3 ~ 4 )  If going for the way of Bake to Transforms, that workflow will be very very cumbersome.
    2560 x 1392 - 783K
    2560 x 1392 - 1M
    2560 x 1392 - 1M
    2560 x 1392 - 991K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
