Can’t fix broken prop, property collision (Solved)
lukon100lukon100 Posts: 852
edited February 2025 in Daz Studio Discussion
I made a prop with 2 custom properties.
I had to re-make the prop (fix inverted normals).
So I loaded in my new fixed geometry, and then re-made the two custom properties.
I saved my prop over the old version, keeping the same name.
Later I discover that one of my two custom properties is gone - did not get saved.
The custom property that was a boolean toggle got re-saved fine.
The custom property that was an 3-position integer switch did not get re-saved and vanished instead.
I tried again, after deleting the prop file and the corrsponding data folder and rebooting Daz Studio. The problem persists in spite of this.
Post edited by lukon100 on
  • lukon100lukon100 Posts: 852
    There is another copy of the original prop, with its properties, in another diretory path of the Daz CMS. Could this be causing the problem?
  • Yes, that sounds very likely.
    Sho' 'nuf. After I moved the original version copies out of CMS, my integer switch properties re-appeared on my new version of the prop, isntantly.
