when something new is added to a store here try to take the time to look at all the promos for it even if at first glance you don't think it's an item you don't think of use to you as you never know what gem you maybe missing out on because quite often clothing sets which as they are may not be appealing if you really look at what each piece offers you can find many items you can mix and match to create your own outfit many complain oh I like this outfit but hate the shoes or that dress and top don't look good together answer is simply use another combination different shoes or whatever a lot of these outfits are not just one combined piece of clothing you can't mix and match with others sadly yes some are but most not and many have if you look at each promo pic have movement morphs which yeah is important for things like dresses like that detention outfit for teen josie 7 that looks and sounds like it has a lot of movement morphs and just because it's listed shown on a teen character doesn't mean older women don't wear dresses and shirts/ties like this so always really look at everything otherwise you could be missing out on something you didn't relise could be of great use to your projects
I threw this together in 10 minutes. All 3 bits of clothes and the hair were 3D-Age items for V4. The adjustment morphs didn't help very much, honestly. Smoothing modifier with collision iterations of 5 on the skirt, plus tweaking of handles (Converted as tight dress from the Sickleyield projections). The shirt has a smoothing modifier only because I tweaked the bust with the Breast Bridger morphs from the same SY projection template thingies, and then the jacket has the same, plus a very slight push modifier and some handle tweaking with the pelvis.
ETA: This is on the V7 morph for G3F
You can`t use V4 underwear if it comes to panites, you can`t use every skirt, you can`t use every pants, you can use all tops
I can thoriw something together in 2 minutes no problem on that but you are limited in poses and as written if it comes to underwear / panties you get in trouble.
And this is not the issue. I ask myself why content creators for DS are not able to add more styling and adjustment morphs to their clothes. If you have a strap top for example, why is it not possible to create morphs like left strap up/down right strap up/down for example, why is it not possible to add morphs like hips longer/short, left up, right up, front up, back up, left out, right out, front out back out, wider/narrower to name just a view as example, pants, why is it not possible to add morphs like waistline up/down (front,back,left,right,all) hips in/out (front,back,left,right,all) legs longer/shorter, feet in/out (front,back,left,right,all), up/down (front,back,left,right,all) and so on and on and on, I do not understand this.
Why not? SY's template pack and Wear Them All fixes at least most of those issues.
So, I have found a way to fit V4 underwear (panites) nearly perfect to G3F without having trouble that parts of the crotch getting fit to the tighs what causes bad results if you move the tighs to the sides.
It works for 3D-Age panites because of the lots of styling and adjusting morphs (good thing to have such morphs like crotch-sytles and other styles and adjustments like sides front back out for the hip and so on and on and on)
So select your G3F add the panites and select designed for v4 and then select dress - knee-lentgh(do not select pants or any other option like full-body, that will not work acceptable) and you will get an acceptable result. Convert it do SupD but set ViewSubD Level to ZERO (it is a difference compared to base even if the value is at ZERO - Value at zero prevents unwanted mesh effects at the glute gap) and then add the smoothing modifer. If you want and I do this: Add a D-Former to the hip of the panites and fix the scales and transforms of the deformer so you are able to lift up the crotch area of the panites.
If you use 3D-Age panites originally made for V4 you will have crotch styles and and other styling morphs and with these (it just need 3 or 4 of them) you can adjust the crotch area and finished. Fits nearly perfect to G3F then. It can be that you have to adjust the added D-Former for the crotch for some poses (wide spread legs for example but that is fast made and much better than the unwanted mesh effects you will have if you add them as pants)
And by the way, I have nearly all 3D-Age clothes for V4, so I know them.
And you get trouble at some parts if you use pants, glute, crotch, hip area, thighs and that is a fact.
So select your G3F add the panites and select designed for v4 and then select dress - knee-lentgh (do not select pants or any other option like full-body, that will not work acceptable) and you will get an acceptable result. Convert it do SupD but set ViewSubD Level to ZERO (it is a difference compared to base even if the value is at ZERO - Value at zero prevents unwanted mesh effects at the glute gap) and then add the smoothing modifer. If you want and I do this: Add a D-Former to the hip of the panites and fix the scales and transforms of the deformer so you are able to lift up the crotch area of the panites.
Still waiting...
Somehow I don't think saying that has any effect. :)
you may be right Chris but who knows
