the program closes during rendering
Hello everyone.
Today I couldn't complete a rendering because the program crashes and closes at 70% of the rendering and gives me an error.
I hope someone can help me
  • I also attach the screenshot
    1086 x 986 - 357K
  • We would need the regular log, not the cloudlog - that is about Daz Studio working online to get metadata and install content etc.
  • Thanks for the reply.
    Now I'm trying to do that rendering.
    When the window opens after the rendering is blocked it saves me a zip with an errorlog.xml file, a crashdump.dmp file and a cloudLog.txt file inside
    Richard Haseltine ha detto:
    Avremmo bisogno del registro normale, non del cloudlog, che riguarda il lavoro online di Daz Studio per ottenere metadati e installare contenuti ecc.
  • Rendering stopped abnormally again. I attach a screenshot. I restarted Daz and downloaded the log.txt file
    I hope someone can help me solve this problem. Thanks
    1798 x 878 - 641K
    txt
    txt
    log.txt
    5M
  • Hmm, the log just stops mid-render so nothing very helpful there. It might be worth using GPU-Z, from techPower Up, to monitor the GPU as your render - see if it is getting too hot, or memory is getting tight.
  •  I finished a new rendering with some more elements to test and it didn't crash. Maybe there's something wrong with this composition...
  • Perhaps something about the data sent to iray is just weid enough to trigger an issue. If the scene reliably crashes you could make an error report via a support ticket, attaching the log, the crash report, and the scene file.
  •  Ok, thanks, I'll see if I can do some cleaning and try again. If the problem persists I'll send a support ticket
