Toon Base T-Shirt textures not loading [SOLVED!!]
faisanfaisan Posts: 600
edited February 8 in The Commons
I installed the new 4.23 Daz Studio because I wanted to use the new G9 Toon Figures, but when I loaded the Toon Base T-shirt on the Base Anime Masculine, the materials don't load, neither the defualt blue texture (it's only black).
Any idea how to solve this issue?
Post edited by faisan on
  • Richard HaseltineRichard Haseltine Posts: 108,169
    You have updated the Genesis 9 Starter Essentials?
  • faisanfaisan Posts: 600
    Yes, but I'll install them again. I'll write again if I keep having this issue.
    I updated again the G9 starter essentials, but I keep having the same issue with the shirt. I have to say I don't have any problem with the rest of the clothes (male and female), only with the shirt.
    1280 x 1789 - 949K
    This is what my Log says:
    2025-02-06 17:04:56.577 [INFO] :: Begin asset load (open): /People/Genesis 9 Toon/Clothing/Daz Originals/Base Clothing/Toon Base T-Shirt.duf
    2025-02-06 17:04:56.607 [INFO] :: Clearing the scene...
    2025-02-06 17:04:56.644 [INFO] :: *** Scene Cleared ***
    2025-02-06 17:04:56.648 [INFO] :: Determining missing assets...
    2025-02-06 17:04:57.765 [INFO] :: Setting textures...
    2025-02-06 17:04:57.767 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(6476): Node parent not found.
    2025-02-06 17:04:58.068 [INFO] :: Scanning for addons...
    2025-02-06 17:04:58.307 [INFO] :: Creating node geometry...
    2025-02-06 17:04:58.317 [INFO] :: Creating UV sets...
    2025-02-06 17:04:58.317 [INFO] :: Creating materials...
    2025-02-06 17:05:01.068 [INFO] :: Resolving legacy figures...
    2025-02-06 17:05:01.069 [INFO] :: Preparing modifiers...
    2025-02-06 17:05:01.070 [INFO] :: Creating modifiers...
    2025-02-06 17:05:01.157 [INFO] :: Resolving 10 formulas...
    2025-02-06 17:05:01.157 [INFO] :: Finding formula properties...
    2025-02-06 17:05:01.158 [INFO] :: Sorting formula properties...
    2025-02-06 17:05:01.158 [INFO] :: Creating ERC Links...
    2025-02-06 17:05:01.158 [INFO] :: Finished resolving formulas.
    2025-02-06 17:05:01.158 [INFO] :: Finalizing modifiers...
    2025-02-06 17:05:01.158 [INFO] :: Finalizing channels...
    2025-02-06 17:05:01.158 [INFO] :: Finalizing materials...
    2025-02-06 17:05:01.159 [INFO] :: Sorting property groups...
    2025-02-06 17:05:01.161 [INFO] :: Setting up follow targets...
    2025-02-06 17:05:01.161 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(2823): Failed to follow node.
    2025-02-06 17:05:01.178 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 9 Starter Essentials/G9 Base Shirt/Morphs/Daz 3D/Base/FitOverPants2.dsf
    2025-02-06 17:05:01.316 [INFO] :: Finished asset load (open): 0m 4.740s - /People/Genesis 9 Toon/Clothing/Daz Originals/Base Clothing/Toon Base T-Shirt.duf
    2025-02-06 17:05:01.837 [INFO] :: Unlocking viewport redraw...
    2025-02-06 17:05:01.838 [INFO] :: Viewport redraw unlocked.
    2025-02-06 17:05:02.582 [INFO] :: Loaded image: BaseToon_TShirt5Stripes_BaseColor.jpg
    Any idea, guys?
  • 3Diva3Diva Posts: 11,974
    First, let's find out a couple of things to make sure of, to see if we can noodle out what the issue is:
    1) Are you using the Filament draw option? https://www.daz3d.com/forums/discussion/comment/9041351/#Comment_9041351
    2) Do you have a Filament Draw Options Node in the scene?
    3) Do you have at least one distant light in the scene?
    4) Are you using a PC (and not a Mac)? (I believe that Filatoon isn't usable on Mac at the moment but they're working on fixing that.)
    If those four are a yes, make sure you have these installed and UPDATED: Default Resources for Daz Studio 4.23+ (or whatever the current version of that is), Genesis 9 Starter Essentials, Genesis 9 Starter Essentials Expansion.
    edited February 7
    1.- Yes
    2.- I don't know what is that? Could you explain me, please?
    3.- Yes
    4.- PC
    5.- Where can I get the Updated Default Resources? I have installed G9 starter essentials and its expansion.
    I want to add that I don't have any problem with the rest of the clothes (males and females) or hairs. Only with the T-shirt.
    edited February 7
    1.- Yes
    3.- Yes
    4.- PC
    To load a Filament Draw Options Node go to the top menu "Create" and select "Filament Draw Options Node" (it will be near the bottom of the dropdown list):
    As for not having issues with the other clothing, are you sure? Could you post a render of it, because looking at the skin of the image you posted, the shaders do not look right. So I'm wondering if you just don't have all the resources installed that are needed.
    Do you use DIM (Daz Install Manager)? If not I HIGHLY recommend it as it makes installing and managing products so much easier. Do a search in there for Default Resources for Daz Studio and make sure you have that updated.
    380 x 780 - 46K
    Post edited by 3Diva on
    Here I attach a render. Like you can see, all the textures work perfect (skin tones, hairs, eyes, shorts and the female clothes). The only is the t-shirt, showing itself black. Do you have a link of the Default Resources? I don't get to find it.
    1920 x 1200 - 1M
    I have updated the Default Resources and I keep having the issue :( According to the log file, the problem is a \src\sdksource\fileinput\dzassetdaz.cpp(2823).
    Any idea for solving this issue?
    edited February 7
    That actually looks right (except for the shirt, as you pointed out), so I'm not sure if there is an issue with your resources or not. I don't think that the Default Resources can be downloaded manually, I have only seen them available to download via DIM (but I could be wrong on that, maybe someone else can verify if there's an alternative way to download the Daz Studio Default Resources).
    Could you try this scene and see what it looks like to you (see attached scene DUF file)?
    It should look like this:
    1000 x 1300 - 882K
    duf
    duf
    Toon Shirt Test Scene.duf
    599K
    A meesage appeared: "The files listed below could not be found: /data/Daz 3D/Genesis 9/Base/Morphs/Spearcarrier's Ghostfox/Genesis Transfer Poses/Transfer Genesis 2M to 9.dsf
    When I click Ok, I keep having the issue :(
    1000 x 1300 - 609K
    Yeah, that is very weird! (The morph you can ignore, it's likely a freebie morph from Spearcarrier that didn't get saved right or something). But it's so strange that the shirt is black still. I have no idea what might be causing that. As you shown, your other toon clothing looks fine. It's just so weird.
    edited February 7
    In the log file appeared these warnings:
    But I have no idea how to solve it. I hope someone of the Daz team can help me.
    edited February 7
    I'm sorry I couldn't help you find the problem. It looks almost like the geometry shell for the toon shirt doesn't have the right shader or something and is just showing up as black. If you hide the toon outline does it still show up black? (You can find the toon outline in the Scene Tab if you expand the shirt and click on the eye icon):
    281 x 96 - 7K
    Oh! You were a great help, thank you so much for that! :) But sadly no: even hiding the outline can fix the issue :(
    That's a bummer and a real mystery, considering the other toon clothing looks correct. :( I hope you're able to find the solution.
  • crosswindcrosswind Posts: 9,580
    Select Base Shirt in Scene tab, go to Surfaces pane, is the filatoon shader correctly set ? as well as the material settings look good ?
  • WonderlandWonderland Posts: 7,134
    Can you show a screenshot of your surfaces pane? Can you find BaseToon_TShirt5Stripes_BaseColor.jpg in the textures folder on your computer?
    Yes, I checked out the Surfaces tab and everything looks correct, and I have the jpg file in my textures folder. (Plus the rest of the materials work correct with the rest of the clothes). I insist in the warnings that the Log File shows me:
    2025-02-07 14:23:56.135 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(6476): Node parent not found.
    2025-02-07 14:23:59.079 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(2823): Failed to follow node.
    I think the problem comes from that dzassetdaz.cpp file, but I don't know how to solve it.
    That is the code module that is reporting the issue, the issue it is reporting that it cannot find the parent of the current node it is processing; perhaps theer is a naming issue. I do note that you reproted a message relating to a morph transfer tool earlier - is it possible that you used some tool to (for example) trasnfer some morphs into the clothing and that the saved file from that is being found, and loaded, before the unmodified file from Starter Essentials?
    The transfer issue was with the file was sent to me for testing the texture on the t-shirt, but it wasn't mine. So, no, I didn't save any morph into the clothes, and like I said before, I don't have any problem with the rest of the clothes, only with the t-shirt.
    edited February 7
    I reinstall the G9 starter essentials with the DIM and I keep having the same issue with the t-shirt only :(
    Also, I noticed that the material is loaded correctly in NVIDIA Iray view. The problem is with the Filament view.
    edited February 8
    Odd ~~
    Do you have the latest DS Public Build installed ? If you do, suggest you also try it in Public Build.
    If you don't, order it in here https://www.daz3d.com/daz-studio-beta and install it via DIM.
    Post edited by crosswind on
    crosswind said:
    Odd ~~
    I've installed it, but I keep having the issue sadly :(
    Here I leave the last Log File, when I loaded the T-shirt, in order to someone can help me to detect the problem. I keep having the same warnings:
    2025-02-08 16:57:03.859 [INFO] :: Prepare asset load (open): /People/Genesis 9 Toon/Clothing/Daz Originals/Base Clothing/Toon Base T-Shirt.duf
    2025-02-08 16:57:03.859 [INFO] :: Locking viewport redraw...
    2025-02-08 16:57:03.859 [INFO] :: Viewport redraw locked.
    2025-02-08 16:57:04.016 [VERBOSE] :: Native format content directories: 2
    2025-02-08 16:57:04.016 [VERBOSE] :: Poser format content directories: 4
    2025-02-08 16:57:04.017 [VERBOSE] :: Other import format content directories: 0
    2025-02-08 16:57:04.017 [INFO] :: Begin asset load (open): /People/Genesis 9 Toon/Clothing/Daz Originals/Base Clothing/Toon Base T-Shirt.duf
    2025-02-08 16:57:04.580 [INFO] :: Clearing the scene...
    2025-02-08 16:57:04.644 [INFO] :: *** Scene Cleared ***
    2025-02-08 16:57:04.648 [INFO] :: Determining missing assets...
    2025-02-08 16:57:06.485 [INFO] :: Setting textures...
    2025-02-08 16:57:06.552 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(6476): Node parent not found.
    2025-02-08 16:57:07.362 [INFO] :: Scanning for addons...
    2025-02-08 16:57:07.738 [INFO] :: Creating node geometry...
    2025-02-08 16:57:07.986 [INFO] :: Creating UV sets...
    2025-02-08 16:57:07.986 [INFO] :: Creating materials...
    2025-02-08 16:57:11.638 [INFO] :: Resolving legacy figures...
    2025-02-08 16:57:11.638 [INFO] :: Preparing modifiers...
    2025-02-08 16:57:11.639 [INFO] :: Creating modifiers...
    2025-02-08 16:57:11.805 [INFO] :: Resolving 10 formulas...
    2025-02-08 16:57:11.805 [INFO] :: Finding formula properties...
    2025-02-08 16:57:11.806 [INFO] :: Sorting formula properties...
    2025-02-08 16:57:11.807 [INFO] :: Creating ERC Links...
    2025-02-08 16:57:11.807 [INFO] :: Finished resolving formulas.
    2025-02-08 16:57:11.807 [INFO] :: Finalizing modifiers...
    2025-02-08 16:57:11.807 [INFO] :: Finalizing channels...
    2025-02-08 16:57:11.807 [INFO] :: Finalizing materials...
    2025-02-08 16:57:11.807 [INFO] :: Sorting property groups...
    2025-02-08 16:57:11.810 [INFO] :: Setting up follow targets...
    2025-02-08 16:57:11.810 [WARNING] :: \src\sdksource\fileinput\dzassetdaz.cpp(2823): Failed to follow node.
    2025-02-08 16:57:11.951 [INFO] :: Loaded morph deltas: 0m 0.4s - /data/Daz 3D/Genesis 9 Starter Essentials/G9 Base Shirt/Morphs/Daz 3D/Base/FitOverPants2.dsf
    2025-02-08 16:57:12.791 [INFO] :: Finished asset load (open): 0m 8.775s - /People/Genesis 9 Toon/Clothing/Daz Originals/Base Clothing/Toon Base T-Shirt.duf
    2025-02-08 16:57:14.786 [INFO] :: Unlocking viewport redraw...
    2025-02-08 16:57:14.786 [INFO] :: Viewport redraw unlocked.
    2025-02-08 16:57:16.282 [INFO] :: Loaded image: BaseToon_TShirt5Stripes_BaseColor.jpg
    Finally I got to solve it! I had to load the FilaToon - General shader from the FilaToon shader presets. However, when I apply a new texture, it's neccesary to load the general shader again, because it keeps appearing black. So, I can say: issue solved!
    I leave this solution in case someone else has the same issue in the future.
    Thanks to the people who tried to help me, I appreciate so much your interest! :)
    I'm really glad you found a workaround for the issue. It's unfortunate that the cause of the issue was never found, but I'm really glad you were able to fix it by applying a Filatoon shader to it. :)
    Yeah, I'd have liked to know the cause too, because every time I load a new material I have to load the general shader too, but well, at least I could get they can be viewed in the Filament view. Thank you so much for all your suggestions. I appreciate so much your interest for helping me :)
    The issue you had was really odd ~ but the warnings in the above log more likely resulted from that you did not select G9 figure before loading the T-Shirt. I could reproduce the very same log by doing so ~~
    A final suggestion you may try : press F2 in DS, Clear DSON Cache Files. Reload G9 Toon figure and this T-Shirt, see what you'll get.
    Yes, when I got this log file I didn't load the genesis 9 figure, but this kept happening even when I loaded the figure first. And I tried your last suggestion but it didn't work either sadly :( But it's okay, at least I found a solution. Thank you so much for all your suggestions! :)
